Question about Music
Need 6.3 amp 125 V Fuse 3/4 of an inch in length & 1/4 inch in diameter
  • 4,234 Answers
If you look on the defective fuse, it should be marked GMA with a amperage rating. Look locally for a GMS type fuse. These are usually available at Best Buy or any other electronics stores.
Dan
Posted on Jul 11, 2010
Loud crackling on several pots
Sounds like your pots are dirty. You need to spray a cleaner such as Deoxit in the pots then rotate them a few times..This has to be done with the power off and the amp unplugged from the wall...Remove the knobs, get some food grade plastic hose which will be a snug fit when shoved on over the shafts of the pots...make sure to cut a piece off the hose about one inch in length...spray the cleaner into the hose and then with the hose still shoved down over the shafts rotate the shafts back and forth a few times...Then power up the amp and recheck...This will only work if the pots are not gone beyond the point of no return..Outside of that, they will need to be replaced which means you will have to disassemble the unit...
Jan 12, 2014 | Crate CA125DG Telluride Acoustic Guitar...
I have a behringer eurolive b212d no power no lights on when I push the button I hear a clike in the speaker but no power. tested the fuse its ok. could there be a fuse inside the power unit .any help...
Eurolive Active speakers from Behringer suffers of bad power supply/Amp design, if you open up the back of your speaker you will probably find that the AC connector has a burnt or loose connection as well as a black spot, if not, check the power supply/power amp coils for cracked connections, let me know for improve help.
Sep 20, 2013 | Behringer B212D Powered Speaker (550...
Hey my Pyle pro heavy metal distortion peddle isn't working. Everythings fine until I switch to distortion, than no sound comes from my amp. Any suggestions?
Check the switch to see if it is functional with an ohm meter. Also check length of plug and make sure it engages the jack securely as there are about 5 different lengths of 1/4 inch jack available. Are the effects powered by battery or through the amp, or on thier own power?
Jan 27, 2012 | Music
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
I cannot get the grand piano sound......help somebody!
You are not clear if you can't select it or it just doesn't sound like a grand piano. If it is the latter here are the things to check:
1. Are your speakers at least 15 inch diameter with suitable tweeter as well? This is if you want the deep lows of the piano. Twelve inch are minimum size to sound anything like a grand. The internal speakers found in the pianos just don't quite make it as they are often only 4 to 6 inch.
2. Is your amplifier capable of enough power?
To get the REAL GOOD grand sound you need a capable audio system. A home stereo system just doesn't cut it to reproduce the sound of a grand piano.
Mar 09, 2011 | Kurzweil SP2XS Keyboard Home
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
When i turn on my line 6 spider 3 amp it keeps blowing the fuse
MOST likely the power amp chip is blown. They use a TDA2050 chip that is in a seven lead power tab package similar to the TO220 transistor package. Readily available from DigiKey.com for just under $3.
If you keep replacing the fuse, you may damage other components.
The other possibilty is a diode and/or filter capacitor has shorted.
Jul 17, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Looking at what I think is a magnavox speaker. basket has these #s P-232 914 p meaning alnico, 232 meaning magnavox. it also has 1D3309 and has 472 6 on the cone. What do these mean? Is it a bass or full...
A 5 watt guitar amp is puny. A decent size speaker would be a minimum of 10 inches diameter. A minimal guitar amp (except for the PigNOse type) would be at least 15 watts.
Try the speaker... It is unlikely you can get much data on the speaker as it may have been made special for the organ it came from. The other numbers are probably production run numbers.
Mar 17, 2010 | Music
Music Logo
65 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
