Question about Shure E3g Consumer Headphones
Shure E3G losing sound in one ear
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
See the following FAQ on this topic:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=3407
Posted on Jul 15, 2010
I have only used my Shure psm 200 one time and I had trouble with highs. When I would belt out a high note the sound would distort or go away completely. I hope you can help, I'm really hoping to love the...
Brief research didn't turn up "protection" circuitry that could possibly cause your audio "go away completely" but I will assume that the distortion issue is just because the system is set up incorrectly. In-ear systems can be tricky to adjust as too much volume can distort the tiny "ear-bud" type earphones, and damage your hearing. Check online for your model as I found a manual that specifically addresses safe volume levels at the beginning of the owners manual, followed by operational settings, etc.
Mar 27, 2015 | Shure Audio Players & Recorders
Tip
SHURE E3g EARPHONE PROBLEM
IF YOU HAVE THE SAME PROBLEM WHAT I HAD WITH MY 3 YEAR OLD SURE E3g EARPHONE THAT ONE SIDE IS NOT LAUD ENOUGH......<br /> I DID TRY ALL THE CLEANING WITH THE PROVIDED TOOL BUT ALL DID NOT HELP.<br /> I DID USE A KNIFE AND DID SLOWELY FOLLOW THE GROVE ARROUND THE TIP OF MY BAD EARPHONE. AFTER A FEW MIN. WORKING WITH MY KNIFE IN THIS GROVE I DID FEEL THAT THE EARPHONE WILL COME APART. THE TIP HAS NO CONNECTIONS (ELECTRICAL SPEAKER WIRE CONNECTIONS) NOTHING IT IS JUST THE EARPHONE PLASTIC TIP. AFTER I HAD THE TIP IN MY HAND I USED A NEEDLE AND I GOT A LOT OLD EAR WAX OUT AND MY EARPHONE IS VERY LOAD AGAIN. NOW CLEAN BOTH SIDES AND PRESS THE TIP BACK ON. IF YOU FEEL BETTER USE A DROP SUPER GLUE TO BE SURE IT WILL NOT COME APART AGAIN AND STUCK IN YOUR EAR. I DID NOT USE ANY GLUE.<br /> I HOPE THIS DID HELP YOU TO CONTINUE TO LISTEN YOUR MUSIC WITH YOUR SURE E3g EARPHONE
on Mar 18, 2011 | Audio Players & Recorders
I can only get sound out of one ear. Sometimes, if I move the chord around, I can get sound our of both ears. It comes and goes.
I have had this problem several times. It can be due to a number of things
Firstly, try the MP3 player with a different set of headphones, if both ears work, then the headphones are the problem. Check the adaptor and/or cabling for any damage or defects. If the internal cabling is damaged, you will need to go and buy a new pair.
If the problem is the player itself, try checking the headphone port for dust or any other artefacts blocking the way. This can cause he connection to fail and therefore lose sound.
On a side note, if you love listening to music, i would suggest a high quality set of headphones. Sennheiser (my personal favourites) and Shure are both a VERY good brand to go for. You do pay a bit more, but sound quality and build quality are faultless.
Feb 28, 2011 | Audio Players & Recorders
I have bought a pair of Shure SE210 headphones for my iphone but the sound is lacking all the low frequencies for most of the music or videos i try to play. The headphones work perfectly on any other...
No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
Jul 07, 2010 | Shure SE210 Consumer Headphones
Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
May 01, 2010 | Shure E3C Consumer Headphones
Shure SCL3 - replacement parts
Sorry, replacement nozzles are not available, as the nozzles are not user changeable. Contact Shure Service at 800-516-2525 and you'll be able to send them in for repair/replacement cheaper than purchasing a new one.
Jan 19, 2010 | Shure SCL3 Headphones
One ear bud does not have full sound, i think it might be ear wax any way to safely clean with out damaging the speaker?
This is caused by microscopic wax build up in one ear. You'll probably have to send the earphones to Shure for replacement.
Sep 29, 2009 | Shure E4C Consumer Headphones
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
Shure E3g Consumer Headphones Logo
129 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Bobby G
Bobby G
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
