Question about Vizio L32 32 in. LCD HDTV
Our TV was tipped over and the picture is now just a buch of
Scattered lines. The sound works fine. Can this be repaired or is the tv a total loss?
  • playballglq Jul 12, 2010
    Yes, thanks for the info!
  • 10,594 Answers
If scattered lines are caused by hitting some thing on screen then lcd screen is broken and repair would cost you more then tv worth.
And if those lines are straight then visual check is needed to determine is it t-con (lcd controller) board or lcd panel got defective.
Local tv repair shop will help you to confirm after visual check of tv that what got bad in tv.
Thanks.
Posted on Jul 10, 2010
My LG LCD TV screen was tapped and color is scattered. Can it be fixed?
It sounds like your TV screen got hit with an object
If the answer is YES! your LCD the panel is gone.
Replacing the panel costs more than buying a new TV.
Jul 24, 2014 | Televison & Video
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
Emerson TV 19 inch, model TS1995
most liekly these set dont last to long
there is a fuse but that requires taking the set apart, unless you know what you are doing it might not be a good idea with professional help.
but most likely its a total loss since these set are cheaply made and from china.
its would cost more to repair it that to buy a new one.
good luck
Jun 14, 2008 | Emerson SpongeBob SquarePants TV
Poor picture quality
You need to consider the following tips herein as follow:
1) Field collapse (horizontal white line on screen)
R710 dry joints. Same as C2146TN & C2546TN problem solved with thanks to Mike G & Barty. Power off/unplug. Get to circuit board underside with aerial socket up-R710 is near top and right of centre-cluster of 4 joints best resoldered
2) Picture is horizontally narrowed and deformed
Capacitor C2913 (390nF, 250V) on the deflector PCB had lost capacity
Please let me know any update
Nov 29, 2007 | Toshiba 27AF42 27" TV
Vizio L32 32 in. LCD HDTV Logo
49 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
