Question about ViewSonic VX2235wm LCD Monitor
Monitor turn of black out and turn back on with analog on the display on and on like that untill turn of the monitor
  • 11,361 Answers
Check for bad caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
LCD MONITOR:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Posted on Jul 11, 2010
Testimonial: "thank you for your support,i will open up and see inside then Ilet you know .once again thanks so much"
    Problem Solver:
I cannot remove the back. need info..
Posted on Jun 28, 2011
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
The display on the Dell SE198 dispays while it is searching for the input mode. It displays for aproximatelly 2-3 seconds while it confirms that it is recieving analog input. Afterwards the motitor "seems"...
Turn your computer off.
Turn your computer on, and immediately keep tapping the 'F8' key,
until you see a "boot-menu".
If you never see that menu, connect the monitor to a different computer, e.g., a laptop, and see if the monitor works at all.
When you see the boot-menu, select "Safe Mode".
Reset the video-resolution to 800-by-600, and restart.
Nov 14, 2009 | Dell SE198WFP LCD Monitor
Lcd screen goes black after a few seconds
check your vga cable that is connected on your cpu,for some lose connection,it must be fitted if you still don't get any display check your cpu.have some other monitor for isolation,if you dont have bring it on s repair center,your cpu has a problem.
Sep 10, 2009 | Computers & Internet
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
May 24, 2009 | ViewSonic VA721 17" LCD Monitor
How do i turn the brightness down on a sony TFT
What model do you have? Either way, there should be buttons underneath or at the bottom of the monitor. If not marked, start pressing until one is displayed that shows choices. That would be your menu settings. If you don't need the choice displayed, do nothing and in a few seconds it will disappear.Most likely, the one you need will be in the appearance of a sun or light bulb. The rest of the buttons will allow you to toggle between choices and then adjust up or down (or left and right for positioning). If you don't like changes that have been made, there is always a selection that lets you restore to factory default settings so have fun experimenting.
If you have a display with dual inputs - one for analog (blue cord ends) and digital (white cord endings), make sure you don't choose the wrong input. Your screen will go black until you put it back to the correct input. Let me know if you have further questions.
Jan 10, 2009 | Sony SDM-S73/B Monitor
My new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Oct 05, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
New 19" flat screen monitor only shows analog on the screen
finwiz,
When you on your computer, does any thing appear on the screen, some text display/logo etc.?
If yes then:
  • After making power on your computer start pressing F8 till boot option menu appears.
  • Then select safe mode and if it works, then goto device manager and re-install driver for your display.
If no then:
  • Check out the connection from monitor to computer and try. If still no luck then post comment whats you did and what was the result.
Thanks
Iqbal
May 12, 2008 | Gateway FPD2275W LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
"analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Sep 09, 2007 | LG Flatron L1750S 17" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
667 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
