Question about 3Com 10/100 32-bit CardBus LAN PC Card (90332542) Network Adapter
My computer has a 3com 10/100 NIC. It is detected by the computer. I am running windows XP. But I can not connect to the internet to set up a new account.It seems tat the otside modem that is attached is not detected.
  • 977 Answers
Hi again!
Modems that are connected through ethernet cable requires no setup/installation/driver!
The only thing you need is to configure the actual connection to the internet. Please refer to your Intrenet Service Provider's website/support for more info, as there are various connection types, depending on your subscription and your specific ISP network type.
You should, in any case, get connected to the modem itself...
Do you get a message saying "network cable is disconnected and/or see an icon of 2 computers with a red X on top??:
* If yes, check the cables (if you haven't done so) and make sure the modem works properly (all necessary LEDs are on, etc.). Chage the cable if necessary or contact your ISP if your detect any problem with the modem.
* If not, only the connection setup is required!
Good luck,
Pelu.
Posted on Jul 11, 2010
Have an HP pavilion a340n that I have restored, now can't get any network driver to work. Doesn't recognize the on board or any NIC card I try to install. The only card it reads I can not find a...
a340, circa 2003? wow, old...Goodwill has them way newer why use this old dog ?
why post lacking what OS this is?
xp dead
Vista dead
3com drivers, dead. about year 2000 dead, 17 years dead.
Windows 7 does not support many old chips.
nor does 10. (worse)
so?
if motivated to make NIC work
why not just buy a new NIC card from say newegg
or is this restore, a go back to windows 95,
back in the hey day of 3com, HP owns 3com now
but the those products all died back 17 long years ago
3com NICs 3C905 card, or the like?
I can run the PCI scanner on that PC
its a free program and get the
MFG code and device code. telling what chips both are.
nic and on board.
go here, find what matches your unstated os
buy it and it works.
PCI card, Rosewell.? $9 says comes with CD
says does all OS , see that?
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100158104%201100858365%20600016289%20600013857&IsNodeId=1&Description=nic%20card&bop=And&Order=PRICE&PageSize=36/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=nic+card&N=-1&isNodeId=1
ever use a PCI scanner to ID that on board chip
hell both .
http://pcdied.com/pci-101.html
if 9bucks is too much, only this scanner can tell you whats there in hardware.
the HP books are gone. long ago.
Jun 26, 2017 | HP Pavilion a340n (DQ099AABA) PC Desktop
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Aug 23, 2010 | SMC WBR14-N Router
My asus Eeepc 1005HA has Linux and Windows XP. i can connect to internet via Linux but not Via Windows XP either Wireless or Etherness. I tried two other laptop and both of them connected to internet my...
Make sure that the drivers for both the NIC (ethernet) and wireless are installed. Then you will need to reset the TCP/IP.
In Windows XP click on the start menu and then click on Run. In the box type cmd and hit the enter key. A command window will open up. type in the window netsh int ip reset c:\resetlog.txt and hit enter.
2 new registry keys will be wrote in the registy >>>>>>>
SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
Reboot the Windows OS and hopefully you can then access the net via both types of connections.
Regards.
Mar 08, 2010 | ASUS Eee 4G Notebook
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
All started with wireless router (Belkin)
Actually, is does **t really matter what computer *********** in law has or whether she has a computer or **t. Your wireless connection is **t with her computer, it is with the router.
I take it for granted that the router has got a wireless facility , since you said you set it up. Your computer must then also be wireless enabled (internal or Using an USB Dongle).
Set the connection type on the router and your computer as such that there is ** authorization or encryption involved - once you got that working please the ensure that you activate authorization and encryption for security reasons
Mar 09, 2008 | Microsoft Windows XP Professional
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Clean XP Pro installed -- now NIC disappeared!
Well once you did a clean install over all of Dell drivers etc etc. You wiped out the restore artion that was on the computer. You have to go to Dells website and under the support tab look for the Nic card that you have inside the computer.
Feb 08, 2008 | Dell Latitude C610 Notebook
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
3Com 10/100 32-bit CardBus LAN PC Card (90332542) Network Adapter Logo
94 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
