Question about Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
Water slowly coming out of dispenser
For the first two months the dispenser worked perfect. For the last two weeks, it started coming out very slowly. I am not patient enough to wait 2 minutes for 16 ounce glass to fill up.
  • Whirlpool Master
  • 3,740 Answers
Is this a new Unit or a second hand unit? If it is not new... most likely there is debris in the water valve inlet or the actual saddle valve / faucett connection to the refrigerator water supply line is partially blocked.
Without a Model number to ensure the exact parts inside the unit for you to check is a bit of a problem.
Most of the water valves are the same and an example of yours would be item 10 of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132635&diagram_id=945271#d945271
detailed view: http://www.appliancepartspros.com/part_details.aspx?part_id=3160649
- What I recommend you do is disconnect the water supply line on the back of the unit and check 16 oz. of water flow at the end of the supply line. Water OFF before disconnecting the supply line.
- IF the water flow is the same as through the door you will need to find out why there is not enough flow from the water supply source.
- Additionally IF you have a water filter installed external to the unit... it can be clogged or full of sediment and need to be changed.
- If you discover that the water supply is of good quantity and pressure there is also the possibility of a pinched or kinked plastic water line some where inside the refrigerator.
- Sometimes the hose that passes through the door hinge flattens out and restricts water flow.
Thanks for using FixYa.
Kelly
Posted on Jul 11, 2010
LG fridge LRSC26915SW -= water dispenser and ice are not getting water
Replace water filter, this unit had a issue with restrictions in filter due to a design issue. Water valve is all so called a water pump from many people.
Aug 17, 2012 | LG LRSC26915SW 36" Side-by-Side...
Refrigerator about 5 years old. stopped dispensing water twice in last 12 months. Ice and crushed ice works perfectly. No water for last 2 months. Whats up?
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Nov 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
May 09, 2009 | Refrigerators
Water not dispensing/flow is not fast
Sound like time for a new filter. When was the last time it was changed? If less than a year or two, it's not the problem. If more, it's likely the filter is clogged reducing the pressure flow of water.
Dec 28, 2008 | GE Refrigerators
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
My GE Refrigerator Clicks for hours but will not start.
Clicking you describe sounds like a bad motherboard. Water dispenser issues have been result of frozen water in the tubing in the bottom of the FF area, which you should not have at the moment, so if it is not dispensing water now I'd check the water valve coil. (there are two coils on the inlet valve, one for the icemaker and one for the water dispenser.)
Sep 26, 2008 | GE GSL25JFR Brushed Steel Side by Side...
Water dispenser woes
the water would have got blocked near the valve any dust particle would have got struck near the valve which is not allowing the water to flow to remove the dust u take the outlet pipe and blow with force the dust which has struck would get released and would work perfectly
Jul 30, 2008 | GE Refrigerators
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
