Question about Goodman CLQ36AR49 Air Conditioner
Need a parts list for a goodman heat pump model cpkj 48-18
Control box parts were stolen.
  • 22 Answers
Your best bet is to go to www.goodmanmfg.com make sure you have exact model # of your unit and if there is no help for you there then call the help line that this site gives you.Once you get the list of exactly which parts you need you can get univeral parts or order right from that site i gave you.approx cost about 300.00 hope this helps
Posted on Jul 11, 2010
What is the compressor part number for a Goodman heat pump model PHKJ036
ZR32K5EPFV800 is the OEM part number. I have to ask why you believe the compressor is bad.
Feb 24, 2017 | Goodman Heating & Cooling
Goodman HP Model ARUF18241BA locked on Strip Heat, thermostat has no control, outside unit off. What Circuit Board is corrupt?
Sounds like either a stuck relay or stuck contactor. Not a difficult fix if you have right part. Turn power off and locate how high voltage gets to the heat strip. If there is a black box on a circuit board than it would be that whole piece.
Dec 19, 2016 | Goodman Heating & Cooling
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman heat pump model gph1442h41aa will not turn on
first confirm that the condensing unit outside is getting power or even a command to come on .check function of thermostat your t-stat may command heat in the cooling mode.instead of the heat mode, being a heating system generated by a cooling condensor. also check bateries in t-stat. make sure breker in the panel box is on ,it is a double breaker usualy marked with an amp rating of 20 ,or a 30 on it . also check disconnect switch located next to your outdoor condensor usualy a gray box on wall of building. make sure its on or diconnect tab is pluged in . hope this was helpful. good luck.
Feb 11, 2013 | Goodman GPH1524M41 2 Ton 15 SEER...
I have a heat pump model ARUF 042-00A-1A. There is only air blowing but no heat comming out. What can we do? Thanks
Heat pumps are like a refrigerator. Check the "pump" part is working properly. and is cooling one side, heating the other.
If not - maybe run out of gas (needing technical repair and refill) - or a motor fault.
Dec 27, 2010 | Goodman Heating & Cooling
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
Jun 16, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
518 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
