Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Our refrigerator constantly leaks from the top of the refrigerator section near where the lightning & temp controls are located.
  • Whirlpool Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorOur refrigerator constantly leaks from the top of - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
Where is the temp control on the older (14 yrs or so) on GMD-12?
The thermostat on GDM models is located on the evaporator section usually on the top right or left.
Apr 09, 2014 | True GDM-12 Refrigerator Commercial
Sears Kenmore refrigerator odor in freezer?
A quick phone call to Sears or a local appliance service center may be in order. Since the evaporator that cools everything is located inside or very near the back of the freezer and the freezer has the lowest air circulation of the entire refrigerator, I would suspect a small refrigerant leak. Many refrigerants have strong odorizing chemicals added for just this purpose. Natural gas for heating has these same chemicals to warn us of the danger if a leak occurs. If it is a leak it's not dangerous, but very soon you will come home to a warm fridge and thawed food. Prior to that you'll hear the fridge running constantly as it tries to maintain the proper temp.
Mar 09, 2013 | Refrigerators
My GE Adora freezer section constantly gets down to -5 to -9 degrees, when the setting is 0.
I would advise replaceing # 4 AND # 5 thermistor . The # 4 , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( remove the inside rear freezer panel ) , with 2 white wires going to it . Part number WR55X10025 for both . The # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jun 13, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Temperature in fridge is going up. temp now 45. Ice is forming on inside top rear of fridge
Hi again, the defrost timer is located near the temperature controls in your refrigerator. The control looks like nothing more than a hole, that is larger than the screw holes near it. When you find it, you will know its the right part by pushing your finger or other object in and it makes a ratcheting sound as it rotates.
Mar 14, 2010 | Arctic Air R22CWF Refrigerator Commercial
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Where is the Adaptive defrost control located on FRS26LF8C$3?
The adaptive defrost control is the PC board located in the refrigerator section inside the temp controls housing. If you remove the control housing at the top of the refrigerator section, it is on the left side behind the temperature controls, the only board thats in there.
Oct 07, 2009 | Frigidaire FRS26R4A Side by Side...
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
