Question about Amcor 14000 Portable Air Conditioner
Only blows air, compressor comes on but there is no cooling
I just set upm the device after purchase and there is no cooling.
  • Amcor Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
My window unit is not blowing cold air. Ive used it a handful of times and it never got cold. How do i fix this?
There are very many possible causes. You do not indicate your model number, but many units take a few minutes before the compressor comes on. If the compressor is not coming on (a low rumble sound, NOT the fan), you'll get no cooling. If the compressor is coming on, and you still get no cooling, it is likely your unit needs a recharge. Things to check: Is the thermostat set lower than the room temperature? Is the unit set to "fan only"? I hope this helps lead you to the problem and a solution.
May 09, 2014 | Heating & Cooling
We have model #57915.54. The fan and compressor run, but is blowing hot air. Is there freon for the unit? If so, I heard that there was a kit you could purchase to do it.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure. If leak call repairman to rectify it.
Jan 11, 2011 | Heating & Cooling
Does not blow cold air
check your compressor first to see if it comes on, then the freon inlets and outlets. one side should be hot or warm and the other should be cool or cold. If not 1. check the fan or blower for the cooling fins to see if it is blowing. 2. call your manufacturer to see if a capacitor or switch could cause the apparent problem (either the cooling fan not blowing or the compressor not coming on) . this info is for a house a/c but should not be muich different
Jun 09, 2010 | LG GL6000ER Air Conditioner
My lg a/c only blows air with no cooling what is
possible a tstat problem or compressor is not coming on...put your ear by the ac unit...if you hear a buzzing noise ,then shuts off,humming...compressor not coming on...
May 09, 2010 | LG LB1200ER Air Conditioner
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
Air conditioner not blowing cold air. We put coolant with gauge reading 25 lbs pressure. We think the compressor is coming on. The pipe coming out of the compressor is cool but, the air coming into the car...
Is the air actually blowing into the car?But it's just hot?It sounds like your blower motor is not turning to blow air.you have a fuse,check the switch that controls the blower,and the blower motor it self.
Jul 27, 2009 | Saturn L-Series Cars & Trucks
Air conditioner is set on cool & furnace is turning on
probably your compressor not running or the air con is out of Refrigerant.
Jun 06, 2009 | Intertherm P3RA-048K Air Conditioner
AC keeps blowing fuses
Fuses are a protection device and I guess that this is for the condenser section and compressor. If they blow right now when it is turned on would indicate that there is a short in the wiring or motor or compressor. If it trys to start and the outside fan starts and the compressor just humms and blows fuse, you have a locked compressor. Might check run capacitor or install a hard start kit and see if it will brake it loose, if not bad compressor
May 31, 2008 | Ruud UBHC Air Conditioner
Amcor 14000 Portable Air Conditioner Logo
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
