Denon AVR-2106 powers off on its own. Even after restarting, it continues to power off. This happened last night so it has had time to cool down and I did not change any of the speaker settings.
  • ronno Apr 19, 2008
    Many times always with the same result. It begins to start but shuts down again after about 5 seconds. The on/standby light quickly flashes red when it is off.
    There are no Denon authorized repair facilities around Phoenix. Can any audio repair shop perform this fix? Is there anything else I should mention when I bring it in?
    Master:
    Sergeant:
  • 462 Answers
Did u try to power it back on after letting it cool down...?
Posted on Apr 19, 2008
  • Mohamed Ismail
    Mohamed Ismail Apr 19, 2008
    This is very clear and evident that in your power supply section board there are some capacitors which have been worn out and you need to replace them.
    Thankyou
  • Mohamed Ismail
    Dont worry... Its simple just take it to any electronic repair shop and explain the problem, i am sure you will get it done.
    For further assistance you can always contact me.
    All the best.. Have a nice day...!!!
    Thankyou
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
My Denon AVR 2106 gives sound out periodically in all modes
So you have no sound on any Inputs?  This makes a difference, if it works on some inputs but not others.  For a factory reset - turn the unit off by the ON/OFF button (not the standby button) hold in the SPEAkER A & B buttons at the smae time, while pressing them turn the system on by the ON/OFF button, wait about 3 seconds and the unit should reset everything.
Jan 01, 2009 | Denon AVR-2106 Receiver
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
Aug 30, 2008 | Denon AVR-2106 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
Denon avr 3000
Anyone want to buy a working Denon AVR-300?
hdurity@comcast.net
Dec 01, 2007 | Denon AVR-2106 Receiver
HAVE TO UP VOLUME ON DENON 2106 TO HEAR ALL AUDIO IN NIGHT MODE
There should be a volume adjust on the center channel. This is done by the remote exclusively. You may also wish to compress the sound using the dynamic range compression button or so labeled.
Aug 31, 2007 | Denon AVR-2106 Receiver
Powers turns on then off
See: http://www.denon.ca/hapdfs/avr2105mane.pdf, page 72. In my case, the problem was a connector between my receiver and television. I unplugged it from my receiver and it now works.
Dec 03, 2006 | Denon AVR-2106 Receiver
42 people viewed this question
 Grubhead
Grubhead
