Question about GE Advantium 120 Convection/Microwave Oven
I've ordered and received a new door for my Advantium 120 oven but have no idea how to take off the old door and put on the new one. Can you help?
    President:
  • 1,099 Answers
Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help, because they have the procedure
If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage.
You should definitely mark the locations of all the hardware before disassembly.
Good luck
Posted on Jul 11, 2010
  • Sanyade Akinwale
    Sanyade Akinwale Jul 11, 2010
    Hello.
    Also note that you follow the below steps.
  • Shut off the power to your oven at the home's circuit breaker box. If you have a gas oven, close the gas shut-off valve.
  • Step 2Take off the old door, if applicable to your oven. Skip this step if this is a new installation. Lower the door until it is all the way open. Open the hinge locks with a flathead screwdriver to release the door. If you have a self-cleaning oven, remove the metal clamps or brackets that hold the hinges in place with a Phillips screwdriver. Close the door partially until it is in the "broil" position. With a firm hold on each side of the door, lift up and slide the door off of the oven's hinge arms.
  • Step 3Hold up the new door and match up the slots on the door with the hinge arms on the oven. Place the door onto the hinge arms and lower the door until it is all the way open. Use your flathead screwdriver to move the hinge locks back to the locked position. Replace any brackets or clamps that were removed in Step 2 if you have a self-cleaning oven.
  • Step 4Make sure the door fits properly by opening and shutting it a few times. Pay attention to any points where the door seems to grab or catch on something. Lift the door off and re-install it if you notice any problems.
  • Step 5Switch the circuit breaker for your oven back on and turn on the gas supply, if necessary.
  • Hope this helpout........
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Wherte can I find the service /repair manual for the Advantium 120? Need to get into the door light switch. thanks
The service manual and installation instructions are here.
Our help file on door switches is here.
You can find helpful exploded view diagrams and order parts & accessories here.
Dec 04, 2011 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
Handle on the front of our GE Advantium 120 broke off need to find a replacement. We live just north of Boston MA
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The actual Advantium 120 service manual is at our site here.
You can find handy exploded views and order parts by model number here.
Dec 16, 2010 | GE Advantium 120 Convection/Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
Broken bottom latch on GE Advantium 120
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Broken Bottom Latch Pawl GE Advantium 120 Microwave
Dec 24, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 door handle breakage
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Aug 01, 2008 | GE Advantium 120 Convection/Microwave Oven
Power Out
Common problem with the Advantium. Culprit is a thermal cut off (TCO) for the cavity. Other posts detail where it is. I ordered a replacement at the link below.
http://www.mouser.com/search/ProductDetail.aspx?qs=i1kXDmddXkNuE3oXZkbuYw%3d%3d
Jan 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
52 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
