Question about Hayward 1.5 Hp Northstar High Performance Pump
My pump is issung a burnt smell and ended up stopping al together
  • Hayward Master
  • 1,383 Answers
SOUND LIKE YOUR MOTOR IS TOAST ! DO TO THE COST OF MOTORS FOR THESE , REPLACE THE COMPLETE PUMP WITH A 1.5 HP STA-RITE DURA GLASS ! OR YOU MIGHT NEED A 2HP.. LOOK ON YOUR MOTOR LABEL FOR THE HP AND THE SF . TAKE A PICTURE OF IT AND PRINT IT OUT. BRING THIS INFO TO YOUR LOCAL POOL PUMP REPAIR GUY AND ASK WHATS THE BEST PUMP. THE ONE HE WOULD USE ON HIS POOL.. ANSWER ..STA-RITE.. WELCOME TO THE HAYWARD NORTHSTAR .. REMEMBER TO VOTE OR COMMENT .. IT IS THE FUEL TO KEEP ME TRYING TO HELP U GUYS .. JAY
Posted on Aug 19, 2010
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
My car is hard to turn, it makes an awful noise and is smoking, it smells like burnt rubber, if i continue to drive it what will happen
Hi Debbie,
Not sure with out looking at it, But from what you posted if hard to turn
sounds like your power steering punp aint working , ant if smoking and smells like burnt rubber sounds like pumps locked up, (pully not turning) and if so continuing to drive it could leave you on side of road if it runs a cerpintine belt , that kind of belt runs every thing and if breaks water pump stops flowing water motor will over heat, you should realy have someone look at that for you.
Feb 05, 2014 | Dodge Cars & Trucks
The washer was in spinning cycle, when I smelled plastic burning, then it stop all together. I was able to turn it off, but now it doesn't do anything. What could this be?
It will be good to start with looking into the washer with the power switched off smelling for the source that burnt. this will be easy to find and the possible area could be the power section in the main board- the control board.
Once you have isolated the burnt component we can decide if the part alone can be changed or the full board needs a change.
The motor and the drain pump also must be checked for any burnt outs.
Dec 02, 2010 | GE WSXH208A Front Load Washer
Will a failing power steering pump smell like burnt rubber ? One line seems to be leaking but the smell seems wrong.
If the pump is starting to seize up, the belt maybe slipping on the pump pulley, causing the burnt rubber smell.
May 13, 2010 | 1989 Mercury Grand Marquis
Washing machine stopped spinning after several loads, and I smell a slight burning smell, won;t drain either.
it sounds like u might have some electrical problem in the controls however it may be the pump itsself has gone out but if u r getting an electrical smell could be causing the pump not to get power or the pump has burnt up causing the wires to get hot and start to melt myy bet is that the pump has gone out its not horribly bad to change out but kind of difficult for someone who isnt used to doing this kind of stuff
Feb 25, 2010 | Washing Machines
My 1999 Dodge Durango started a noise inthe front and I had two cv joints put on but the noise continuedand later stopped.Then one day I was driving down a mojor interstate and the steering wheel would...
check the power steering pump pull the cap of and smell the fluid if it smell very burnt then you may have to replace it,if this seems ok the jack the vehicle up and support the front end on jack stands start the vehicle and see if the wheel turns then if it does then see if you can pinpoint where the noises are coming from it will either be the pump or the steering rack,also check the tie rod ends and related joints for binding or damage
Jan 04, 2010 | 1999 Dodge Durango
Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
Aug 13, 2009 | Magic Chef CAV4000AWW Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Hayward 1.5 Hp Northstar High Performance Pump Logo
257 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
