Question about Mitsubishi WT-46807 46" Rear Projection Television
Power trouble My wt-46807 only powers on for about 2 seconds then shuts off. Tried to reset my unplugging to no avail. Can you help?
  • relevare Jun 09, 2008
    same problem
You need a multimeter to diagnos the issue. I have one with the same problem that i had gotten for free. I found that two of the fuses that are soldered to the middle board are bad... i have not tried replacing them yet but i will repost.
Posted on Aug 09, 2008
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 No power on
Well, obviously you need to replace them. What exactly are you looking for us to help you with.
Mar 29, 2008 | Televison & Video
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Last night the set just turned off by itself. When I try to power on, the power light comes on for a second and then it shuts itself off again.
I am having this exact problem. The TV turned off by itself and now when I try to turn it on, the power light stays on for a sec and goes of with a click sound.
Any TV experts who can HELP?
Apr 20, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Powering down
THAT'S CORRECT, YOU NEED SOMEONE WITH ELECTRONICS SKILLS TO FIX THIS PROBLEM. YOU HAVE A POWER SUPPLY PROBLEM AND I BELIEVE THAT THE CONVERGENCE IC'S HAVE TO BE REPLACED TOO.SO CALL AN EXPERT IT WON'T COST MORE THAN $350.00
Aug 25, 2008 | Mitsubishi WT-46807 46" Rear Projection...
PUSH POWER AND SHUTS OFF WITHIN SECONDS AUTOMATICALLY
just had this tv fixed for this exact problem-it cost 577 bucks to fix- some sort of control panel that had corroded
Jul 05, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
