Question about Estate TAWS800JQ Top Load Washer
My washer won't drain.
I load it and it washes bt the water won't drain at the end.
  • billylmt Aug 11, 2008
    Washer agitates but it stops mid cycle. Manually turn it to rinse cycle continues to agitates but when it stops to drain nothing happens. Turn it to spin nothing happens. Help!!
    Problem Solver:
  • 3 Answers
I also have this problem. I've tilted the machine and taken the wire 'holder' in place at the exit pipe. The stupid thing won't be yanked off. Am I doing something wrong?
Posted on Jul 31, 2008
  • 487 Answers
Check the lint filter and pump as they can get clogged. Have a few towels ready as it is a wet job
Posted on Apr 19, 2008
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
My washer spin and unlock button starting flashing and when I try to unlock the washer, it won't let me. I have a feeling the load was off balance. What can I do to unlock it?
Access the drain hose and get the end to ground level in a bowl. Empty any water. Clear filter and make sure drain pump is free. Door will now open
May 19, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
I have an LG washer front load WM2032HW. It won't
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
Won't spin off all the water and the belt is not broken
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Frigidaire ATF6000ES Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
115 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
