Question about Peg Perego John Deere Gator HPX Ride on Toy
How does the back lift gate rise and lower. i can not find the unlocking latch
Be hind the dump theres a red ring pull it up
Posted on Jul 16, 2010
Jeep Grand Cherokee 1994
Is it the back hatch? Can you pull the rod on the broke side & pull handle at the same time?
May 19, 2013 | Cars & Trucks
2008 Pontiac Torrent lift gate will not open
Hotnurse37. I'd you fix your problem. I have same issue. Fuse is okay. Remote will open all doors but I can't even hear the rear attempting to unlock. Did get access to emergency release after trying for a long time. Lock and latch looked fine but back to same problem after closing lift.
Apr 04, 2013 | 2008 Pontiac Torrent
2003 buick rendezvous lift gate latch not working
take it to any gm dealer...its a recall and its 100 percent free...type in year make n model with recalls after it
Oct 25, 2011 | 2003 Buick Rendezvous
Liftgate won't open automatically
To open the lift gate manually, use the door unlock switch located on the drivers door. This should unlock the lift gate as well. Go to the lift gate and lift the handle to open the rear gate.
Your power lift gate is computer controlled. Sometimes there will be a faulty input sensor or part that will show the incorrect data to the computer, therefore the computer will not go through its normal functions.
In most cases its the problem of lift gate latch assembly.
To get it tested and confirmed there is a troubleshoot guide provided by the service center. To perform this troubleshooting guide you will require a scan tool to diagnose the exact problem.
the troubleshooting procedure is as follows:---
Please use the following information below when diagnosing an inoperative lift gate. Disconnect the connector at the lift gate latch assembly. With the lift gate latch connector disconnected, the 3 signals for the ratchet, pawl, and the sector should be inactive on the scan tool.
Install a 3A fused jumper wire between each signal circuit terminal (for the pawl, sector, and ratchet) and the ground circuit terminal 2. Monitor the scan tool as each individual circuit is jumped to ground, the scan tool should read "active".
If either tests above fails, check the wiring for the signal circuits, low reference circuit, or try a power lift gate control module from a known good vehicle. If both tests above pass, monitor the internal switch inputs in the lift gate latch assembly for proper operation.
3. A) with the lift gate in the open position, the ratchet and the pawl should read "active" and the sector should read "inactive"
B) With the lift gate in the secondary latched position, the pawl should read "Inactive" and the ratchet and sector should read "active"
C) With the lift gate fully closed, the pawl, ratchet, and the sector should all read "inactive".
4.If one of the internal lift gate latch assembly switch inputs are not reading correctly in one of the positions above and the vehicles passes test 1 and 2 above. Replace the lift gate latch assembly.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
This should help you.Thanks.Helpmech.
Dec 04, 2010 | 2006 Cadillac SRX
Rear door does not close
Look at the door's locking mechanism. Is the Latch Gate in the down position? Is the Door Mechanism properly tightened to the door? These are Torx/Hex head bolts. Tighten these if needed.
If the Latch Gate is down:
1. Unlock the door.
2. Lift up/out on the Door Handle as if you were opening the door.
3. Use a screwdriver to lift the Latch Gate so it lifts the Gate up and out of the way.
Alot of these Gates have plastic coverings that sometimes split and stick or cause the door mechanism to jam. Inspect the Door Mechanism for anything that could be causing it to jam. Using a pair of needle nose pliers remove any of this split plastic (if so equipped) pulling as much of it off the Latch Gate.
Use WD40 with the red spraying hose on and stick it as many openings you can and lubricate as much of the Door Mechanism as you can.
Check the operations (plural) of the Door Mechanism, Opening and Closing the Gate using the screw driver to push in the Striker Gate causing the Latch Gate to rotate back down into position. Repeat... checking for the Latch Gate to Release Up (on it's own) when you "open" the door. If it doesn't, then there is either jammed or a return spring is broken.
Have you dented or distorted the Door and / or Door Mechanism in the process of trying to slam the door close? You will have to either bend the the door area back to as close to possible the original shape. Use the other door on the other sides as a guide on this. You may have to replace the Door Mechanism itself, as when they are malfunctioning and are slammed (over and over) it could break the Mechanism itself. If the Mechanism is broke, you will have to remove and replace the entire mechanism.
Let me know if this helped, or if you have additional information of questions. Feel free to conatct me at FixYa.com!
Jan 17, 2010 | 2005 Saturn Relay
Lift gate wont open
OK, this minor collision may have shifted the actual clip and latch assembly. You may have to totally disassemble the latch assembly to release this lift gate.
Any kind of major or minor shifting of the lift gate lock latch assembly can cause misalignment that will jam this delicate precise locking mechanism.
Apr 23, 2009 | Jeep Grand Cherokee Cars & Trucks
Peg Perego John Deere Gator HPX Ride on Toy Logo
100 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
