Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Have a jvc i-art pro 56" from 2003 have a red halo surrounding images. what can I do to fix this and where do I acquire the parts? Thanks
    Problem Solver:
Red halos
to much red
Posted on Mar 04, 2011
  • JVC Master
  • 8,617 Answers
Thats aconvergence failure. You can get the AV48WP74 convergence repair kit from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions for the repair.
Posted on Jul 11, 2010
I have older projection JVC i Art pro Tv, it is projecting a double image and i need to know how to fix it easily
if model number is correct the two stk-392-110 chips need to be replaced.
Can you solder?
see photos of board in your set and I can tell you how to get it out and what is needed.
Before you rate this information let me know if you can solder etc.
Jul 25, 2011 | JVC AV-56WP74 56" Rear Projection...
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
I opened the set and the blue projecter does not show image like the red and the green. does the blue projecter need to be replaced?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | JVC AV-56WP74 56" Rear Projection...
Pioneer PRO 510HD - 53"
Boards can run 250 - 400.00 on average. You may be better off just repairing the board parts for around 65.00
See below
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Pioneer PRO-530HD 53" Rear Projection...
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
Re: I art jvc
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Aug 14, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC I art Pro HDTV displays RGB images are not aligned and out of sync.
Which model number JVC do you have sounds like you need new convergence amp ICs.
Jun 18, 2008 | Televison & Video
IMAGES ARE OVERLAID AND NOT IN FOCUS
Here is the schematic diagram. Download all the 13 parts and unzip them using winrar.
The parts you need are listed on page # 50 of the schematic diagram.
You will find the ICs HERE.
Make sure you check the fuses and micro/pico fuse nearby the ICs, as well some crystallized solder joints.
Good Luck.
Mar 16, 2008 | Televison & Video
Red streaks
need to have the STK IC's replaced to correct convergence problem
Mar 05, 2008 | JVC AV-27230 27" TV
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
476 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
