It sounds like it's trying to fire up the lamp, unsuccessfully. Try
removing the lamp and putting it back in. Sometimes this helps, at
least temporarily. My initial suspicion is a lamp issue.
Let me know if this fixes the problem and if not, then we can explore further solutions.
Thank you for using Fixya and Good Luck
a projection tv uses a lamp for the picture, so you do have a lamp
Lamps look like this
Let me know if you need further help
yes good, you should try to remove them and then put them back in and see if anything looks dirty or burnt. If putting them back in doesn't fix the problem then you will probably need to replace one or more of them
Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
otherwise please let me know if you have further questions
Thank you
turned it off -same thing
can take the rear off the tv and see if anything is burnt or a fuse is blown etc
It goes off in about a second or less than restarts and does the same thing
SAMSUNG DOES NOT SHOW A LAMP FOR THIS MODEL HCM4216W
Thank you /This unit has 3 lamps of different colors.HCM4216W Samsung
