Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Can anyone tell me where the "choke" is on this Craftsman LT3000? I bought from a friend and he has misplaced the Manuel. It needs a little bit of work. Front lights don't work Tires needs air and the guard for the blade needs a tire on it. Thanks for any information here.
2 Suggested Answers
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Posted on Aug 26, 2009
What size is for a craftsman LT3000 blade belt 42 in deck?
June, google search your make, model #, deck belt.
LT3000 is not a model # , The model and serial number of a Craftsman riding mower is located on the frame under the seat, or on the underside of the seat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Craftsman Garden
Need a replacement splindle for Sears LT3000
The complete spindle is called a mandrel on sears site part number 192870 $47.24. You can also get the housing all by itself and reinstall the shaft and bearings into it part number 187281 $24.60. The shaft is what the blade attaches to and can be purchased separate part number 192872 $17.84. All these parts can be purchased at a local Lawn repair shop for less money just take in these part numbers or your model number with you.
Mar 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Runs on choke a little
sounds like the carburetor has gummed up a bit, and may need adjustments - or, the fuel pickup in the tank has come loose [i.e.: deteriorated fuel lines] - also, make sure your gas mix is FRESH. if your gas mix is more than 2 months old, dump it
Sep 19, 2009 | Craftsman 25cc Gas Line Trimmer
Starts easy and idles well with choke on full. Dies in run
Open the air adjustment screw a bit more. There's usually plastic piece that stops you from opening it up. I always break off the plastic.(damn engineers) It's not getting enough gas.
Aug 14, 2009 | Craftsman 25cc Gas Line Trimmer
I have to run my craftsman 19.5hp lawn tractor (model # 917.270824)with the choke partly open in order for it to run smoothly. What adjustment needs to be done to correct this?
Hi..my name is Keith..and you need to turn the main jet needle out a little bit..its located on the bottom of the float bowl of your carburator..i hope this has helped..if not..please write me back
Jul 08, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
