Question about Brother ML-100 Typewriter
No text show up when typing
No text show up on paper when typing
  • 748 Answers
Do you hear the type hitting the paper? Is the ribbon installed properly and in good working order (a carbon film ribbon is all black, or a cloth one has ink in it)?
Posted on Jul 11, 2010
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Can use a glossy paper?
If the glossy paper is rated for the printer you are using yes. Never use paper that is only rated for inkjet in a laser printer. Many special inkjet papers have coatings that will melt or break down due to the heat of a laser jet and may damage your printer.
Jan 14, 2015 | Office Equipment & Supplies
Canon MP830 Will not print black text I have cleaned printer head with steam and nozzle rocket, cleaned purge pads and reset the waste tank - what can I do next???
Try to set/change the Media Type from Plain Paper to Photo Paper Plus Glossy and print your text with plain paper.. perhaps it would solved your problem. i had the same problem but after done that way. i can print with the black ink, but only after i set the media type become photo paper... (bad English)
May 25, 2010 | Canon Office Equipment & Supplies
The color streaks on the pages
There are several possibilities...
1.The Type setting is wrong for the type of paper or specialty media you are using. Change Paper Type to match the paper or specialty media you are using.
2.The Texture setting is wrong for the type of paper or specialty media you are using. Change Paper Texture from Normal to Smooth or Rough.
3. The Weight setting is wrong for the type of paper or specialty media you are using. Change Paper Weight from Plain to CardStock (or other appropriate weight).
4. The fuser is worn or defective. Replace the fuser.
Oct 14, 2009 | Lexmark C760 Laser Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Will not print in color
Good Evening Richareelita:
Hope that you are wellJ
These are the solutions that I found for you. Personally, I think that you need to update your drivers, but wanted to offer you more than one solution.
Adjust printer settings
Click Start , click Settings, and then click Printers.
Right-click the icon (picture) of the printer.
Click Properties .
In the Properties dialog box, click the Details tab.
Look for the text Print using the following driver .
Under Print using the following driver , verify that the name of the printer is listed.
Click the Color or Color Management tab.
Click Automatic .
Click the Setup tab. If you do not see a Setup tab, click the Device Options tab. If you do not see a Device Options tab, click the Details tab, and then click the Setup button.
Locate the text Print Quality .
For Print Quality, choose Best or Presentation .
Look for the text Paper Type , Media , or Media Choice . If you do not see any of these options, click the Paper tab.
Click in the box under Paper Type , Media , or Media Choice .
In the list that pops up, choose the type of paper or film you are using.
Under Photo Paper printing , choose PhotoREt .
PhotoREt is available only if you have chosen HP brand paper under Paper Type. If you don't have a PhotoREt option, look for the text ICM . If you see ICM , click in its checkbox to add a checkmark, and click OK .
If you see a tab called Advanced , look for text Saturation , Brightness , and Color Tone .
Move the sliders next to Saturation , Brightness , and Color Tone to adjust these settings. If you cannot find these settings, click the Graphics tab and then click the Color button. Choose the options that match the type of document you are printing.
Click OK .
Close the Printers window.
Open the software application that you were using to print.
Try printing.
If this does not work, try updating your drivers or uninstalling and reinstalling your printer software.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Office Equipment & Supplies
Printer does not print
Change the paper type to anything other than plain paper. It works but I do not know why.
Sep 10, 2008 | Canon i850 InkJet Photo Printer
Lexmark P3150
Good Evening HERIB :
First, try updating your drivers or uninstalling and reinstalling your printer software.
Next, try.
Click Properties .
Click Automatic .
Click OK .
Try printing.
Aug 26, 2008 | Lexmark P3150 All-In-One InkJet Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Typewriter
You need to select the TW position it is now in LP or JUST position, hold the code key down and press the 8 untill TW shows in the display.
Dec 10, 2007 | Smith Corona Wordsmith 200 Typewriter
Brother ML-100 Typewriter Logo
93 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
