Question about Casio Unisex Watch AW81D-7AV
Set hands - Casio Unisex Watch AW81D-7AV
    President:
  • 2,501 Answers
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search bo
Posted on Jul 11, 2010
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    How do i set the the 24 hour hand in a rolex 16758
    Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
    Apr 30, 2010 | Bulova Watch
    How to set and use the subdial on my invicta model 5749 gmt watch
    While I'm not familiar with that particular model, most GMT hands are set by turning the crown "backwards" in the date setting position. IOW, if you set the date by pulling the crown out to the first detent and turning it clockwise, turning it counter-clockwise will set the GMT indicator.
    Apr 10, 2010 | Bulova Watch
    Chronograph hands reset to wrong places
    go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
    Enter the number off the back of your watch snd the click on "get setting instructions"
    The instructions include the steps you need to take to zero the hands.
    Feb 01, 2010 | Citizen Eco-Drive Calibre 5700 AT1070-54L...
    How can I set time for my casio wva-105h?
    The digital display sets itself, so I presume that you mean that you want to set the hands.
    To do this, press the lower button on the left hand side until "HS" appears.
    Use one to the buttons on the right hand side to advance or ****** the hands.
    Dec 31, 2009 | Casio WVA105HDA Wave Ceptor watch
    The 24hr hand is meant to keep time in another
    I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
    For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
    I hope this helps.
    Dec 30, 2009 | Invicta Watches
    I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
    Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
    Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
    I think you might have not moved the minute hand forward 5 mins and back.
    You can now set your digital time from your hands setting.
    Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
    Changing the hand time only w/o changing the digital time
    For Casio Waveceptor:
    --- A
    ( ) Button Reference
    --- B
    Set in correct order:
    1) Hand Home Position
    2) Digital Time Set
    1) Hand Home Position:
    Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
    Press B to exit Hand Home Position mode and enter Timekeeping Mode.
    2) Digital Time Set: (hands will self set when done)
    Press and hold B for 5 seconds to enter setting mode.
    Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
    <Order of Items to Set>
    GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
    <Setting each Item>
    GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
    Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
    Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
    For each item, Press A to advance, and B to set.
    Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
    Good luck,
    Techjoel
    May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Setting model number jr3060-59f
    1. set mode to CHR with the bezel fully in.
    2. pull bezel out 2 notches. This will set all (or most) hands to 12.
    3.press A (top button) repeatedly until you get MIN in the left window
    4.turn the bezel to move the min hand forward.
    4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
    5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
    Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    Casio Unisex Watch AW81D-7AV Logo
    62 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
