Question about LG Art Cool LA121CNP wall/window Air Conditioner
No heating or cooling just blowing air pa is indicated on the control
  • LG Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Hot air from drivers side cool air from passenger side
Driver's side blows hot air; passenger side cold air - Hyundai ...
www.hyundai-forums.com/.../294097-drivers-side-blows-hot-air%3B-pa...
Jul 29, 2014 - 3 posts - ‎3 authors I soon noticed that the driver's side blows warm air and the passenger side blowscold air as it should. No amount of adjusting the temp control ...
Hot air on driver side vents - Cold on passenger side - Page 3 ...
www.odyclub.com/.../46646-hot-air-driver-side-vents-cold-passenger-si...
May 9, 2012 - 16 posts - ‎10 authors I have a 2009 EXL Odyssey that just is doing the same thing (warm air on drivers side, cold on passenger). I checked freon levels and ...
Oct 15, 2015 | 2009 Hyundai Sonata
When I put the heat on in my car it blows warm air for a few seconds then goes to blowing out cold air.
The lack of heat in the car has little to do with the car's cooling system, other than the hot coolant is the heat source. 95% of all "no-heat" issues are related to heater controls and/or the heater core itself. Since you get some heat, and then it goes away, this indicates a probable vacuum leak in the heater controls. When you select heat, vacuum is directed to a vacuum motor. This motor operates a vacuum actuator that moves a linkage that moves a door inside the heater box to direct the interior air through the heater core. If this actuator has a leak, it will activate, then as the vacuum leaks off, deactivate. You probably need to have a part replaced in the heater actuator mechanism.
Jan 20, 2015 | 2005 Nissan Altima
Engine dies after over heating
Why is the engine overheating? Air cooled engines will overheat when running too lean a fuel mixture. Is the spark plug colour indicating too lean a fuel mixture?
Mar 12, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
3a fuse blowing on the blower motor board
The 3 amp fuse blowing indicates some control function is either grounding out (probably a worn insulation on control wire) or one or more of the solenoid controls is pulling more wattage than it is designed to draw. The solenoids for the main contactor and reversing valves should only draw about 0.1 to 0.25 amp. Any more than this the solenoid overheats and causes the control fuse to blow. I have actually had to replace the thermostat wire on some units because the control that was pulling more than designed caused the entire length of thermostat wire to overheat and break down the insulation, causing the control wire to short to the common wire or others and cause more than required operations to occur simultaniosly. One unit had a short and emergy heat was coming on the same time cooling was on.
Feb 23, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Dash vents blowing cool air instead of heat
You have problem in 1) Your air flow system have gone down and some plastic valves that opens to cold position or to hot position is broken. Solution: remove panel and check this plastic valves that controls airflow.
2) Your heat salon radiator is very poor and can't blow in all directions. Solution: replace salon heat radiator.
3) Your cooling system don't have good limit of coolant. Solution: fil it to min - max position.
4) Your cooling system isn't bleeding. Solution: make system without air in it.
Hope this will helps.
Oct 04, 2013 | 2001 Audi TT
Over heating and sputtering
kohler engine air cool they will over heat if fuel system lean carburetor clogged out of adjustment causing lean fuel mixture,air cool engine need plenty air to keep cool, make sure air filter clean and make sure cooling fins not clogged with debris make sure shrouds and blower housing are tight so air can circulate. air cooling engines kinda remind you of 1963 corvairs
Sep 09, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
On my 2009 1500 silverado, the driver side air cond blows HOT air as if the heat is on, but if you cycle the driver side temp control up then back down several times or turn the truck off like short trips...
There is a damper that controls whether heat or cooling or somewhere between that is controlled by the temperature controls. A separate system is controlling the passenger side and the driver side heating and cooling. I hope this is still under warrantee. If not it might be a big job to diagnose whether the problem is in the heat and cool controller, the wiring or the damper device. I hope this helps.
Aug 07, 2011 | Chevrolet 1500 Cars & Trucks
Heat pump is not kicking in, no heat at 42 degree outdoor temp
HI,
Most likely has a freon leak , or a control problem causing heat to turn on, or if you have a heatpump the reversing valve has a problem.
Oct 10, 2008 | Amana PTH123B35AE Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
163 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
