Question about Nespresso Le Cube
My cube has stopped punching holes in the front section of the pod and only the 4 at the back this gives very weak coffee everything else seems ok
  • 2,272 Answers
Check water tank, if empty, fill with fresh water. Fill up the water pump Open and push lever back as far as it will go for 3 seconds. Press cup button. Wait until water flows. Close lever and press cup button to stop water flow. Empty capsule container / Check that no capsule is blocked inside the capsule container. If nothing helps then try cleaning the machine.If still the problem then it can be broken lever it has to be checked. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
After the pod is put into the machine doesn't pump the water through
had that probleme ( if you check the pin that pierce that k cup or pod ( it has small hole in it take a tooth pick and put it true that hole to get the dried up coffee out ( if that seem to not work ( u can blow in that needle also) and if that dont work take the top off ( screws ) and find the feeding line could full of dried up coffee ... ;) that is your problem
May 14, 2017 | Coffee Makers & Espresso Machines
Why won't it brew?
Have you cleaned the two little holes in the head?
Mine quit working and I used a paperclip, straightened out, inserted into each hole then ran a cup through, inserted paperclip again, ran another cup of water through, then it worked like new again. These little holes get filled with coffee grounds as they punch through the top of the pod, this is where the water comes out to make your coffee. I now clean these two holes every 3 months or so. Keeps it working beautifully!
Nov 25, 2015 | Keurig K10 K-cup Mini Plus Coffeemaker...
Coming out in short spurt will not coffee cut up
there are a few things that can cause this;
1) You may need to clean the needle in the coffee exit where the coffee pod sits and gets pierced when the top is closed. You do this with a needle, be careful the point of the piercing nozzle is sharp and the needle point is as well.
2) There is also a needle in the cup holder under the pod that cuts the hole for the coffee stream, this needs to be cleaned with the needle.
3) The filter in the water tank may be plugged and needs to be cleaned.
4) The pump may be clogged with lime and scale.
5) The heater element may be scaled with lime.
6) Items #3 to 5), to fix this use DE-scalier, or vinegar solution, the pickling strength works better than household variety, but both are OK.
7) run the cycle for coffee, no pod, 3 times, this should clear the taste of the vinegar.
Hope this is your solution.
Mar 17, 2015 | Keurig B70 Coffee Maker
Recently the machine started dispensing VERY weak (mostly water with a very light brown see through color) coffee. It does not happen every time although all coffee seems weak. It looks like the pods...
Hi imhofag,
The first thing to do is clean the projections on the piercers. Gunk will build up on them and they need to be cleaned periodically.
I would need your model number in order to help you take it apart.
Please reply if cleaning the projections doesn't help.
Thanks,
Handie Andie
Jun 11, 2011 | Nespresso Coffee Makers & Espresso...
I have model b44. Water is not moving--nothing is getting to the pod, the pod is getting punched but no water.
hello sounds like you have a bigger issue
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Keurig B60 Coffee Maker
The TI-84 Plus Silver Edition - when dealing with roots and powers - how do you punch in the third root of or the fourth root of... also, how do you punch in ...the 3rd root of 8 cubed? or the 2nd root of...
Press the MATH key to bring up the Math menu. Option 3 gives you cubed, option 4 gives you cube root, option 5 gives you nth root.
For example, 3rd root of 8: MATH 4 8 ENTER gives 2.
4th root of 16: 4 MATH 5 16 ENTER gives 2.
Apr 01, 2010 | Texas Instruments Office Equipment &...
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Gaggia Evolution Filtering Weak Coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jan 03, 2009 | Gaggia Evolution Espresso Machine
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Nespresso Le Cube Logo
484 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
