Question about Casio Illuminator AQ150W1EV Wrist Watch
Set time hands - Casio Illuminator AQ150W1EV Wrist Watch
    President:
  • 2,501 Answers
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search bo
Posted on Jul 11, 2010
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Apr 30, 2010 | Bulova Watch
How to adjust the time for casio illuminator watch instructions s-1045DV
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Jan 27, 2010 | Casio Illuminator AQ150W1EV Wrist Watch
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
I think you might have not moved the minute hand forward 5 mins and back.
You can now set your digital time from your hands setting.
Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
WATCH
Press MODE 5 times until you see H-SET on the right side of the dial in the box. Then press the ADJUST button. You will now notice the current TIME you have already set on your watch will appear in the box and flash where H-SET was. This will help you know what time to set the hands on. While holding down the FORWARD button you will see the hand start to move. I could not move mine in reverse, only forward. Simply set the time and you are finished.
Jul 18, 2008 | Casio G-Shock G511-1AV Wrist Watch
Casio Illuminator AQ150W1EV Wrist Watch Logo
195 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
