Question about Nextar MA933A MP3 Player
How do i turn it on to listen
Seriously, i can't turn it on
I was listening to music,then after 30 mins my pioneer vsx d514 shutdown, completely lost power and now does not turn on, any ideas on what has happened
If the unit has no power whatsoever then it's likely an internal fuse in the power supply section has blown. It could have gone for a verity of reasons, replacement might cure the problem, but if it blows again or straight away then there is a more serious problem.
Dec 16, 2016 | Pioneer Audio Players & Recorders
1996 Honda accord won't start started smoking I thought it over heated but it sounds like the engine turns over but it doesn't start help ? Also the speedometer stays on 20mph
If it's not starting at all but turns over listen to it. As it turns does it sound faster than normal like it has no resistance. Of this is the case its quite possible theres no compression which means serious trouble. Could be anything from timing chain/belt to a broken pin holding the timing gear in place or even more serious bent valves etc. etc. If this is not the case it could be as simple as bad spark plugs and wires. That is where I would start if I was sure there was compression as it's the least expensive place to begin and often a cause of many things.
Aug 15, 2014 | 1996 Honda Accord
My behringer XENYX Q502USB has SMOKE coming out. And I had just turned it on. It was only hooked to my PC and no intruments. I was not even recording, but I was simply listening to playback.I've used it...
1- buy a fire extinguisher, sjust in case. 2 take it to a shop, preferably one that works Behringer. Could be your regulators, but sounds like something more serious. Sorry...
Jul 08, 2014 | Behringer Xenyx Q502USB USB Audio Mixer
I got a 2004 dodge stratus and when i try to turn it on it sounds like a machine gun
It sounds like a serious engine failure has occurred you need this sound listened to by an expert.
Sep 17, 2012 | 2004 Dodge Stratus
What wattage speakers do I use with europower ep2500
Wow thats a serious system you have there.God help the neighbours!Anyway here is an example.you need a pretty serious speaker.At 8ohms,you would need something like a 8ohm 450watt speaker system.Anything smaller will stress your amp if you turn it up.The amp would kill smaller speakers or the amp internals(channels)at higher volume.It would be like hooking up a garden hose to a fire hydrant.Something would have to give.hope this helps and happy listening
Oct 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
Cannot find original regulktor
Listen ,if this is the case dont plug anything into your unit unless you can distinguish the PSU's correct characteristics for your make and model--you risk serious damage if the substitute PSU is not correct ---bear in mind universal PSU's come with a myriad of connectors that have to be connected the correct way --again falure to do so will result in serious damage,even risk of injury to yourself.
Sep 17, 2010 | Computers & Internet
ENGINE TURN OFF WHENEVER I APPLY THE BRAKES
You must have a serious vacuum leak under your hood somewhere. Use a stethoscope, or a lenght of vacuum line held to your ear, and wiggle all vacuum lines around while listening for a hissing.
Jun 04, 2009 | 1985 Mercedes-Benz 190
Won't turn on
well this is a very serious problem it could be caused by age or by draning the battery a couple of times plug it in ti ur computer and see if the program recognizes it if not then u are srewed if it does refrsh ur zune by rasing everything and then putting everything back. or try pressing back and up of the pad
Oct 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Gogear mp3 player shut off by itself,and won't turn back on.
Check if it is charged.........................
Connect it to an AC power and see if it turns on................
What sort of battery does it have?
Aug 18, 2008 | Philips GOGEAR SA6045 MP3 Player
Nextar MA933A MP3 Player Logo
94 people viewed this question
Top Nextar Audio Players & Recorders Experts
skyocean
Level 1 Expert
Marvin
Marvin
Robert Graf
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
