Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher door When you open the door it practically falls to the floor, it almost like there is no spring in the door
  • KitchenAid Master
  • 2,605 Answers
Hello Jodi, welcome to Fixya.
Based on your description what you`ve likey experienced is a broken door closer/link kit.
It is a fairly minor procedure to replace it/them. Slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likey broke ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" to name a few.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part # 1159210 @ repairclinic.
I recommend replacing the entire kit, and check the spring itself...that is seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today.
Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
macmarkus :)
Posted on Jul 11, 2010
Why does my dishwasher door fall freely when opened?
There are springs and pulleys that assist the door. They use a nylon rope that is very thin to connect the pulleys door and springs. The rope is most likely broken.
Jan 10, 2016 | Dishwashers
Why does door open too far and is not horizontal to the floor when open?
Besides spring streaches out over time or one rope breaks. Their are like three spots to hook spring to get tension for door. I just replaces both ropes as one broke and hooked springs in middle hole. Takes more time to pull washer out then to replace the ropes
Oct 31, 2015 | LG LDF6810ST Stainless Steel Built-in...
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Mar 09, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
How to replace door springs on lg model LDF6810ST
Found advice from another post for same prob..not tried yet says its not springs but spring cable, part #4933DD 3001B and 2 needed. Poster seem to know what he was talking about
Mar 02, 2013 | LG LDF6810ST Stainless Steel Built-in...
I have a KitchenAid KUDS01FLSS2 and was wondering if it is normal for the door to fall open... what I mean is the door requires to be supported when opening. Otherwise, the door will swing down and almost...
Yes indeed that sounds exactly like the door springs being broken. The springs are fairly easy to replace, what needs to be done to replace the springs is remove the lowest service panel/kick plate and hook the springs on the tub support frame/leg and the other end goes on a notch in the door hinges. The part number for the spring is 8270182 they could be purchased at your local appliance parts store or online at;
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Even though only one may be broke its advisable to replace both at the same time.
Good luck,i hope i have been able to help you fix your dishwasher,
Gene
Aug 13, 2011 | Dishwashers
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The door to the dishwasher is very hard to close. The door also falls down to the floor which makes the carriage/basket fall down as well.
sounds like one or both of your door links are broken check your hinges. you should ahave a large spring and a piece of rope that attaches to the door. let me know if this helps you
Jan 05, 2010 | Frigidaire PLD2855RFC Dishwasher
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
424 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
