Question about Motorola Talkabout T5210 2-Way Radio
Motorola T5210 walkie talkie static
Have a Motorola T5210 walkie talkie that when turned on all I hear is full time static. Tried removing batteries for 5 minutes and reinstalling, nothing changed. Any suggestions?
charal
SOURCE: Were can I buy the walkie talkie Motorola Talkabout T5210 2-Way Radio? thanks...
go to wal mart buy 2 set new cost 30 to 40 pair near to you att franco
Posted on May 17, 2007
Agent Ken
  • 250 Answers
SOURCE: T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jul 03, 2008
eradiostore
  • 1654 Answers
SOURCE: Is kenwood walkie talkie and motorola walkie
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Posted on Oct 05, 2009
eradiostore
  • 1654 Answers
SOURCE: I have 4 motorola walkie talkies but no
The Motorola GP340 radio is a dealer programmable radio. It requires a cable, radio interface box and Motorola proprietary software (which is available by subscription to dealers and qualifying entities).
Posted on Oct 13, 2009
eradiostore
  • 1654 Answers
SOURCE: how do you use dora walkie talkies?
No certain what exact Motorola model the Dora radios are, however, here is a link to the Disney radios user guide: http://www.giantintl.com/ContentManage/manuals/Moto/Disney%20Adventure%202way_User_Manual_E.pdf
And this is a link to the list of user guides: http://shop.giantintl.com/Manuals.asp?offset=30
TalkAbout radios generally operate similarly, so the manual should be of assistance. Check to see your radios are set to the same settings as one another. Static is a sign of a low or defective battery. Try new batteries, or trade the batteries between radios to determine if the batteries are the cause.
Best regards.
Posted on Feb 11, 2010
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
Talkabout T4500 (7 Channels) 2-Way Radio: A Motorola T4500 (small) walkie talkie makes a sta...
One of my T4500 radios does the same thing. When I transmit or the radio is receiving, the interval is interrupted and it takes another 12 seconds to make a popping noise. Weird! I tried to post this as a comment but FixYa kicks out an error so apologies for posting it as a solution!
May 17, 2010 | Motorola Talkabout T4500 (7 Channels)...
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
May 15, 2010 | Motorola Walkie Talkie 2-Way Radio
How do you use dora walkie talkies? I have brought dora walkie talkies and all I hear is static. I was wondering what do I have to do to get them to work?
Best regards.
Feb 11, 2010 | Radio Communications
May 12, 2007 | Motorola Talkabout T5210 2-Way Radio
Motorola Talkabout T5210 2-Way Radio Logo
108 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
