Question about Dell Dimension 2400 PC Desktop
I have a Dell 2400 it starts up fine but after about ten minutes the light turns from green to yellow and I lose any picture it reminds me of a sleep or hibernation mode but I know it does not have that. Any help would be nice.
  • 748 Answers
Is this light on the computer, or on the monitor?
I suspect that it happens when you try to watch a movie or listen to music - something that doesn't involve typing on the keyboard or using the mouse? If so, then your computer goes to suspend mode. You have to open the Control Panel, Power settings, and select an "Always on" power scheme, and additionally change the "monitor off" option to Never. Then click "Apply", close the window and you should be fine.
Posted on Jul 10, 2010
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I have a Dell Dimension 2400. It will power up but nothing will display on the monitor. monitor says it is still in sleep mode. The green power light is on and also the other green light flashes along...
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&SystemID=DIM_PNT_P4_CEL_2400
This a link to get an owners manual from Dell for your system, if you don't already have one. There should be a toubleshooting section as well as sugesstions on how to get out of modes. Ifyou need help with this, let me knowin "add comment' at end of solution.
Mar 16, 2011 | Dell Dimension 2400 PC Desktop
My dell 2400 wil run for sometimes 10 sometimes 45 minutes and the the monitor loses signal and the power light is amber and the hard drive light is green, the diag. lights in the rear are either off or...
The power supply may be going out. Go to the Dell website, select support, enter your service tag number and find your symptom to determine the problem. The lights in the back will help you isolate the issue by cross referencing it to the lights that are lit and not lit.
Nov 02, 2010 | Dell Dimension 2400 PC Desktop
The light on my hard drive is yellow rather than green and my computer will not turn on.
Ordinarily yellow light indicates ACPI standby. On some Dell and HP motherboards the same light also indicates a CPU failure, usually due to overvoltage or overheating.
Turn the PC completely off (unplug from the wall socket). Open the side, so you can see the motherboard with CPU and heat block. Best if you wait some ten-twenty minutes. Plug the power cable and power on the PC. Does it turn on, and does the CPU fan rotate correctly? If the PC turns on, and the fan doesn't, you have a busted fan which needs replacing.
If this doesn't solve the issue, describe exactly how the error happened. Is it a new PC, a PC which already worked and stopped doing so, a DIY assembled machine? Does it never turn on, or does it sometime do?
Aug 20, 2010 | Dell (8N816) Motherboard
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Computer hangs at the Dee Logo
Look at the description for the diagnostic lights on a Dell 2400 here under "A possible expansion card failure has occurred."
If you have recently installed any card (wireless, sound, etc.), then this would be my first suspect.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Dell Dimension 2400 PC Desktop Logo
93 people viewed this question
Clive
Clive
Alun Cox
