Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The screen shows multiple images and colors. - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 8,617 Answers
Install the RCA repair kit called the ITC222 & ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the cd with repair instructions.
Posted on Jul 12, 2010
Proscan 32" LED TV. Picture colors are opposite of correct, mostly reds and yellow. Any movement on screen shows multiple images. Refresh is slow or not working.
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 06, 2016 | Proscan Televison & Video
It showing multiple coloured line and image is not even showing at all. please what do do to rectify the fault
what colors are the lines replace the image units for those colors
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 11, 2015 | Konica Minolta Bizhub C550
Elmo projector
sounds like you did not setup image screen.
Start
control panel
display
change display settings
multiple displays --- extend displays
detect - will show 1 &2 on each screen
apply
Apr 23, 2013 | Printronix T4M Dt/Tt 4-Inch 203 Dpi Rfid...
I can't find how to Cascade on Elements using "Expert Mode" Where is Expert Mode?
Modes are listed on the main screen of Adobe Photoshop Elements. Simply click on EXPERT to get into the expert mode.
The Expert mode has tools to correct color problems, create special effects, and enhance photos. The Quick mode contains simple tools for correcting color and lighting, and commands to quickly fix common problems, such as red eye. The Guided mode contains tools for basic photo edits, guided activities, and photographic effects. If you are new to digital imaging, Quick or Guided modes are a good place to start fixing photos.
If you've worked with image-editing applications before, you'll find that the Expert mode provides a flexible and powerful image-correction environment. It has lighting and color-correction commands, along with tools for fixing image defects, making selections, adding text, and painting on your images. You can rearrange the Expert workspace to best suit your needs. You can move, hide, and show panels, and arrange panels in the Panel Bin. You can also zoom in or out of the photo, scroll to a different area of the document window, and create multiple windows and views.
Oct 25, 2012 | Adobe Photoshop Elements 9
When slide up the screen multiple image
Hi, What causes multiple images on screen is when a flex is faulty multiple images comes out.
The flex is threadlike object that makes the screen ofthe phone display.it is weak and it needs to be replaced.
When you replace it, it will display a normal screen .
Take care.
Jun 15, 2010 | Sony Ericsson W910i Cellular Phone
The picture has ghost images, not lining up
This sounds like a convergence problem. Use the menu functions to reset your set's convergence. If this is not enough, you may need to replace the convergence board.
Feb 17, 2010 | Toshiba 57H82 57" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Color background, and then C255X error code (x depends of the color imaging unit)
Those codes are related to an abnormal toner to carrier ratio. If you are getting multiple errors that could be a control board failure. I will consult Konica Minolta Solutions and post futher as the information becomes available.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
