Question about Whirlpool ACE244XS Air Conditioner
Air conditioner will not blow
My whirlpool air cond. will only make humming noise, no matter what setting it is on the fan will not blow. It was the biggest one made, when I bought it 6 years ago. This the first bit of trouble I have ever had with it. It is a ACQ152XMO, THANKS, Troy B.
  • Whirlpool Master
  • 43,501 Answers
Sound like the motor has gone bad...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
My rooftop air conditioner is making a humming noise, but will not blow out air. The fan will not kick on manually from the thermostat. The humming stops when I turn the thermostat to off.
check the capacitor of the fan motor may be it was bust u can see physical by the size bulge if u found damage. change it to new one with same rating then it will fix your humming problem.
Aug 20, 2016 | Heating & Cooling
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
Ac started chripping then fan quit
Sounds like fan bearing gone. New fan?
Jul 04, 2012 | Whirlpool ACQ189XM Air Conditioner
Zeith lg dlp 3110v00139b how to clean tv fans making noise wont turn on
It may not be the fans if this model uses a color wheel--fans can be cleaned with air to remove all dirt or dust(rest of set as well for that matter)
If possible I would remove cover and try to locate where the sound you are hearing is actually coming from.
Apr 29, 2012 | LG Televison & Video
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Our air con runs, on heat, and after a time cuts out, blows cold and makes a sort of hissing noise (but not a real hiss) and then shuts down. It then restarts after a couple of minutes. Is this normal?
Yes.Think of a heat pump as a A/C in reverce in cool indoor coil is cold&outdoor coil is hot.Naw indoor coil is hot &outdoor coil is cold&fan is pulling in cold air from outside.its going to iceup& go into defrost cycle.If your unit has a timed defrost every 30,60,or90min.(witch ever yours is set for)Defrost control board checks a sensor on cond.coil,if it is frozen unit goes into defost.You will here a swishing noise,iis the reversing of refrigerant.you will also notice the outdoor fan is not operating&at termanation of defrost fan will blow out steem.the other metod is on demand defrost.when coil freezes unit defrosts.
Mar 02, 2010 | Heating & Cooling
When turn to air it does not blow out cool air and makes humming noise, the fan part works ok
Compressor has locked up or gone to groud. The humming is the compressor letting you know its bad.
Dave
Dec 08, 2009 | GE AJCQ08ACB Air Conditioner
When I turn the unit on it doesn't blow out any air it just makes a low humming noise.
The evaporator fan motor is defective. Check if the motor can be turned manually and spins freely. Otherwise the rotor is stuck. Check and lubricate bushings/bearings.Check the fan capacitor. If all of the above is ok, replace evaporator fan motor.
Sep 07, 2009 | Maytag M6X08F2ACOM Air Conditioner
Whirlpool ACE244XS Air Conditioner Logo
253 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
