Question about Danby Heating & Cooling
DAnby Dpac7008 - hoses won't drain we hooked it up as told but seems to not have enough pressure for the water to go outside.. what did we miss ?
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Missing the drain hose connector
A drain hose is a drain hose, go to home depot and get the dimension and lenght you need.
Posted on Jul 22, 2008
  • 340 Answers
SOURCE: connecting a hose to take out condensation Danby dpac7008
you'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Posted on Jun 18, 2009
SOURCE: danby dpac7008 portable air conditioner
how do u turn on a silhouetto dandy floor air condition
Posted on Sep 04, 2010
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 09, 2016 | Danby Heating & Cooling
Danby ddr5511r owner manual
Yess the DDR5511R has the drain hose connection inside the compartment where the water bucket sits. It is at the top right corner. You have to remove the water drawer to see it. At the right side of the unit (on the outside) is a small "door" that flips up so that you can feed a hose throught to the threaded outet inside. The drain hose is not supplied with this unit.
Mar 26, 2012 | Danby Dehumidifiers
I connected a hose extension to the continuous drain hose on the unit. I ran the hose into the tub, but water still goes in the tank. There is water in the hose too, but doesn't seem to drain in the...
Andre, the problem lies in the length of the hose (should be no longer than 5 feet) and trying to drain it into the bath tub. Your dehumidifier relies entirely on gravity to drain. It will not drain upward over the edge of the bath tub. Water gets trapped in the hose, because of this and creates a blockage. When that happens, water is diverted back to the tank.
For continuous darinage, it should be into a floor drain or a sump. So unless yo have one of the aforementioned, continuous drainage is not an option for you.
Hope this helped you understand how it works and what your options are.
Jul 20, 2011 | Danby DPAC7008 Air Conditioner
Water alarm is on. How do i drain. I think I need to hook up a hose in the back of the unit to drain but I don't know the procedure. There are three drains that look ike they would accept a hose, one high...
The hose is optional. If you are lucky enough to have a drain nearby, then route the hose downhill from any of the three holes on the back. But it won't pump the water uphill out a window. In that case, you will have to install the ginormous external tank and empty it every day. fun fun
Aug 05, 2010 | Danby DPAC120068 Air Conditioner
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
I just bought a Danby portable air conditioner (model # dpac5070). The manual tells you how to use the direct drain hose if you want to "vent" the water outside. If I don't want to direct the water...
You use the hose only for continuous draining outside of the unit into a bucket or what have you. You don't need to attach the hose at all. I actually need the hose if you want to part with yours. coatings(at)shaw.ca
Jul 04, 2009 | Danby Heating & Cooling
Connecting a hose to take out condensation Danby dpac7008
Jun 18, 2009 | Danby DPAC9030 Air Conditioner
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Heating & Cooling Logo
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
