Question about Dell Inspiron 9300 PC Notebook
The curser keeps jumping from the current spot back to somewhere where I've already typed
  • 748 Answers
Are you relatively new to this laptop?
I'm asking, because I suspect that you suffer from the same problem many laptop users have, namely too sensitive touchpad. I myself had this problem with one or two laptops...
When you keep your hands low and parallel to the keyboard, it sometimes happens that when moving the hand slightly to reach keys in the upper keyboard regions, the base of your thumb just barely touches the touchpad, resulting in moving the cursor :) The base of a thumb is protruding lower than the thumb itself, and is not very sensitive to touch, so one does not feel the base barely sliding up the touchpad.
There are two solutions.
First is to go to touchpad settings, and make it less sensitive to light touch. Better yet, some touchpad drivers have a function to prevent from accidental dragging objects by light touch, which needs to be enabled.
If the driver lacks such adjustments, the only remedy is to try and position the hands a bit higher than you currently do. It may be hard at first, but it's relatively easy to form a habit of it :)
Good luck :)
Posted on Jul 10, 2010
All lights work I neede to jump start the car, but I hear a hissing sound where I turn the key, and before I spend the money for battery, what do u think?
if your battery is in the boot get a portable jump starter and connect it to your current battery ive got a 1995 xjr and i did this because this was cheaper and fixing jags tend to be very expensive so if your battery isin the back of your car do so but if your batterys in the front of the car and you really dont want to spend money on a new battery then get a portable jump starter and then every time you go somewhere you would have to connect the portable jump starter up to your current battery and start it that way
Jul 21, 2013 | 2000 Jaguar S-Type
When typing, cursor jumps backward several spaces
Sounds like your mousepad is ghosting. This means it thinks you're tapping the mousepad as you type, which will make it type exactly where you nlast moved the curser to. First, try cleaning the pad thoroughly with a damp tissue, and dry it well... if that doesn't solve it, you could try adjusting the mousepad sensitivity controls on the control panel. Hope that helps.
Oct 10, 2012 | Acer Aspire 5733Z-4633
While typing on Acer Aspire the typing jumps around constantly...why?
Most of the time disabling the tapping for the touchpad solves the problem. Go to settings and disable the tapping for the touchpad, not the touchpad itself, just the tapping.
Nov 14, 2017 | Computers & Internet
Why does my curser jump when I'm typing a word. It jumps so it may type some where else.
Sometimes because the keyboard bent for the pressure on it or from somewhere on the shell of your notebook. So try not to put a hand on the notebook but just fingers on keyboard. Sometimes you hand slightly touch the touch pad and send the cursor somewhere else. you can try to cover the touch pad or disable it while typing.
Jan 15, 2011 | Toshiba Satellite M45-S265 Notebook
I have an Acer Aspire 5315 Laptop computer. The curser jumps all over the place when I am typing and when you happen to look down then look up the curser with be somewhere else and you have to correct and...
This is usually caused from the touch pad just below the keyboard. The easiest fix is to turn the touch pad off when you are going to do a lot of typing.
Jan 05, 2011 | Computers & Internet
When i am typing something my curser jumps and types over something I've already typed. example: when i am typing hing my curser jumps and typesomet
Have you found the answer yet? I don't know that particular laptop but if you use the touchpad, it happened to me because even the lightest brush against the surface with a stray finger would make the cursor jump all over and do the same quite annoying thing as you described.
May 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
My curser keeps jumping into the middle of my sentence when i type.
If you have a laptop with a touchpad just below the spacebar be careful that you are not accidentally hitting the touchpad. I had an identical problem on one of my laptops, and simply switching to using a mouse and turning off the touchpad fixed the problem for me.
May 27, 2009 | Computers & Internet
While typing the curser will jump to somewhere on the page
is this on a laptop
turn off touch pad features
if not this may suggest a virus activity
Jul 12, 2008 | Acer Computers & Internet
Dell Inspiron 9300 PC Notebook Logo
205 people viewed this question
Alun Cox
