Question about Keurig B60 Coffee Maker
WATER WON'T COME THRU TO THE CUP
ALL IT DOES IS DRIP. I'VE TRIED FILLING THE WATER RESEVOIR
WITH STRAIGHT VINEGAR AND IT STILL JUST DRIPS. HELP
  • 3 Answers
It could be your needle (the one on the top of the machine). Try using a pin to clean out the top needle.
Posted on Jul 11, 2010
Keurig won't work if there is a K-cup in however water flows through perfectly without it?
TRY..Lifting up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be.
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO IT:
Pour approx 48 ouncs of white vinegar into the water resevoir. PLacew a large mug on the drip tray, DO NOT use a K-Cup, press the brew button. Pour contents into sink. REPEAT this process until the ADD WATER idicator light, lights up. Let brewer stand for at least 4 hours while it is on. Discard any residual vinegar in the resevoir and rinse thorughly.
FILL the resevoir with fresh water. Place a lage mug on the drip tray and hit brew, again NO K-CUP, pour contents of mug into sink.REPEAT until "ADD WATER" is indicated.
YOU MAY NEED TO REPEAT THE RINSE CYCLE IF YOU NOTICE ANY RESIDUAL VINEGAR TASTE
GOOD
Nov 23, 2013 | Keurig Elite B40 Coffee Maker
Need to descale k75.
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Nov 02, 2013 | Keurig K75 Black Platinum Coffee Maker w...
Leaking water out of bottom and will not brew a full cup
HERES HOW TO DO THAT...
RINSE:
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Apr 14, 2013 | Keurig Platinum B70 Coffee Maker
Water just trickle half cup
RINSE:
Mar 01, 2013 | Keurig B31BLACK Mini Brewer Black 1-c
My coffee maker is making an unusual "squeegee" sound when heating the water.
RINSE:
Jan 11, 2013 | Keurig Special Edition B60 Coffee Maker
Mini keurig stops brewing and blows tops off k-cups
RINSE:
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Need to descale it how
RINSE:
Dec 17, 2012 | Keurig Coffee Makers & Espresso Machines
Every other cup seems to stop brewing after a few drops come out. Water drips back into resevoir. I tried the paper clip clean out to no avail!
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 26, 2010 | Keurig B60 Coffee Maker
Water runs thru maker without k-cup inserted but once I put a k-cup into maker the water drips out only and does not fill up the cup but when i remove the k-cup the water continues to run thru it.
Dec 20, 2010 | Keurig B70 Coffee Maker
Cant find my manual and I dont recall what descaling means. It is stuck on this and wont do anything. Please advise
According to the owner's manual, you sould empty the water resevoir. Fill the water resevoir with white vinegar (it says 48 oz). Place a ceramic (not paper) cup in the drip tray and run a travel mug cycle with no k-cup in the machine. Throw the vinegar out. Repeat this process until the resevoir is empty. Be sure to open and close the lid so the cup sizes flashes each time. let the brewer sit for 4 hours while still on (the vinegar's still inside). Rinse out the resevoir, fill it with water and run the cycles through until the resevoir is empty again. If there is any residual taste. repeat the rinse. If it still say descale when you're done, the book says to repeat the process.
Nov 28, 2010 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
951 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
