Question about HP LaserJet 3330 All-In-One Printer
I press the start scan button, the printer says waiting for PC - the PC doesn't respond so the scan is not made?
  • 223 Answers
It sounds like the destinations are not created, in order to be able to scan from the device you need to configure the scan destinations, and update the printer. you will have to configure the settings on the toolbox as well as the solution center. You should be able to scan from the computer, as long as the full software solution was installed. there is also a fix scan utility available for download on the hp.com website. Use the utility in case you cannot scan from the computer
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using fixya.com
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
How do i delete memory
Hi
On the control/operator panel press and hold the <ON/OFF> button for one second.[Unplug machine if it doesn't shut off after pressing the <ON/OFF> button].
Wait like 10seconds and press the ON/OFF button again.
The machine starts cycling.
Wait until it finishes and then try printing.
Good luck.
Ken
Mar 03, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
I want to scan my document through 3 in one canno MP530, so I load my document in the document tray and press scan button. Bu \t it not respond, so please assit. Thank
Put your document in the feeder on the top or open the hood to put it on the glass. Then press scan and start or "ok" to get the process started. Watch the digital read out on the printer when you press commands.
There are two ways to scan using an all in one printer. One way is requesting the scan by using the software inside the computer. To do that, open the software that came with your printer and click on the scan option, then follow the prompts. Using this method requests the scan from the pc to the printer.
The second way to scan is using the controls on the printer itself to send the scan to the pc. Using this method is a little harder and more complicated then the above stated. When you press scan and then ok or start, the printer might need to search for compatible programs to send your scan to. if this is the case, then you will have to choose from the programs that it retrieves and displays in order to make it happen. if the printer does not automatically locate a compatible program installed on your pc to send your image to, then the scan request cannot be completed and it will error out.
Jul 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
How do i scan something on my pc/
Just use the Scanners & Cameras function in the control panel. Double click this icon to start commencing the scan process. Just make sure the document you are about to scan is already placed in the printer scan bed.
There are also printers that has scan button on their printer. you can use this if you have. Press the Scan button. Wait on your pc and save the documents.
I hope you got the idea.
Please rate this answer with 4 thumbs up.
Thanks
Sep 12, 2010 | Office Equipment & Supplies
My printer is displaying waste ink tank near full press ok key. When I then press the ok key it does not respond. How do I reset it. Many Thanks
Do the following
)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
May 01, 2010 | Canon MultiPASS MP360 All-In-One InkJet...
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
353 people viewed this question
Seeker5211
Seeker5211
