Question about NewAir AC-12000E Portable Air Conditioner
I just received this air conditioner. Set it up
I just received this air conditioner. Set it up as described. Turned it on. The compressor goes on, but the air conditioner does not cool. The display shows 85 degrees and that is the temperature in the room. when I hit the button to decrease the temperature setting the new setting flashes for a short time and then the display goes back to 85 degrees and it does not cool. Any suggestions?
  • 36 Answers
It sounds like you have a faulty unit, that has a bad built in thermostat. I'd suggest sending the unit back for a replacement, or get a refund, & buy another unit. What you may think is the compressor kicking in, might just be the blower fan. Try raising the temperture as high as it will go, & see if you hear a noise change to quieter. If it does get quieter then the compressor was in & is not working properly. Send it back.
Posted on Jul 10, 2010
Car makes a loud sound when the air conditioner is on it does not work the one turned off the loud sound goes away
A/C Compressor is bad. You will need to change the A/C compressor and Receiver Dryer to repair this function. Have the system checked for leaks first. Most Asian cars use DENSO and most European makes, Behr-Hella parts. Do not run the A/C compressor further until you get the system checked.
Mar 12, 2015 | Heating & Cooling
The compressor is running but not cooling.
Try the following to begin operating the air conditioner: 1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extension cord or an adapter plug.) 2. Set the exhaust vent to the CLOSED position. 3. Press “On/Off” button to turn unit on. 5. Press Mode “COOL” 6. Press “TEMP/TIME” up or down V to the desired set temperature. Review the “Air Conditioner Features” section for other settings
Jul 10, 2008 | Frigidaire FAS185N2 Air Conditioner
LG Air Conditioner Model LW1811ERY1 compressor keeps running when turned off
That is called a run cap sound like it needs a new one
Aug 16, 2012 | Heating & Cooling
Rooftop A/C in-op. Clicks when t-stat is turned to "cool" but no fan or compressor. Breaker set, t-stat good.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 25, 2010 | Dometic Rooftop RV Air Conditioner
The air conditioner blows warm air the air compressor appears to be working when the air conditioner switch is turned on the unit is full of freon but the unit will not cool. I was trying to see if it...
First off, does your A/C engage the electro magnetic clutch on the compressor? Is your climate control all set to A/C function? Do you hear or see the radiator fan blowing at a high rate when switch is engaged? Do you see a constant flow of freon at the sight glass by the receiver dryer (little bubbles are fine)? This are just the basic visual test that a auto tech goes through so this might give you a gen idea of what to do easily on your own.
Jul 24, 2010 | Air Tools & Compressors
2005 KA blowing hot air out when set to cold
start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
Jun 24, 2009 | 1999 Ford Taurus
DUO DERM ROOF TOP AIR
yes , this can happen if it sets to long , thats why even cars pumps are engaged when even the heat is turned on , to keep the compressor from siezing up
Nov 06, 2008 | Dometic Rooftop RV Air Conditioner
Compressor runs even when turned off
You could have a relay stuck closed, so every time the power is on it feeds electricity to the compressor.
Mar 10, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
NewAir AC-12000E Portable Air Conditioner Logo
241 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
Lollo Pop
gbob59
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
