Question about Mitsubishi Televison & Video
Big screen TV: Mitsubishi Medallion HD1080 Model #WS 48413:
Mitsubishi Medallion HD1080 Model #WS 48413: PROBLEM: TV turns ON but ''ONLY BLUE SCREEN' no matter which input you go to (no picture, no volume)....when you go to ANTENNA A or B, you do get the buzz noise of no picture on the screen. This set has been functioning fine but recently a power outage/lighning occured and this happens....I tried all adjustments possible including Audio/Video reset but no recovery of the picture or audio....Please advice. Thank you,
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
when the led is flashing does it flash a two digit error code? Let me know I should be able to help you with it.
Posted on May 08, 2008
Slinteriors
  • 8617 Answers
Resistor no R5A73 is a carbon film 10K ohm 1/4 watt 5% resistor. I would suggest getting the service manual as it will break down the xray protection circuit and make it easier to find the problem. You can get one emailed to you at the following link I am one of there support techs and they provide unlimitted free tech support for anyone that purchases a service manual
Posted on May 09, 2008
  • 197 Answers
SOURCE: my mitsubishi medallion hd1080 will not turn on.
bad capasitors in power supply they will be bowed on top
Posted on Jun 09, 2009
SD Tech
  • 14553 Answers
SOURCE: I have an mitsubishi medallion hd1080 big screen
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Posted on Feb 17, 2010
Testimonial: "yes you were right I plugged the tv in tried to turn on shut right down then checked code (menu, input) now 2,2 is the code. thanks"
SOURCE: I have a Mitsubishi Medallion
Watching the Masters and the top part of the tv the color went out it shows green and purple and top half shows double vision...
Posted on Apr 11, 2010
I have a mitsubishi medallion hd1080 60" big screen that just started flickering on and off.
Not knowing the model number I would first look for any signs inside the set of Glycol leaking.
These sets (WS or VS or WT models) have 3 tubes with a sealed area of Glycol for cooling the faces of the tubes.
Confirm actual model number and I will tell you what and where to look.
May 01, 2012 | Televison & Video
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
I have a Mitsubishi projection model WS-48413 that
do you get a click if not check the fuse inside next to the ac cord inside the unit
if you do have a click then your convergance amps let go you will need a tech to replace them qbout 150 dollar job
Nov 19, 2009 | Mitsubishi WS-48413 48" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Mar 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
