Question about Jabra BT350 Wireless Headset
Dont know how to put jabra bluetooth earpiece it into pairing mode
    President:
  • 1,118 Answers
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from this location.
Hope it works for you.
Regards, Carlos
Posted on Jul 10, 2010
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
Can I connect my garmin nuvi 1310T to my Jabra BT2070 bluetooth headset earpiece
You probably cannot. Some bluetooth devices act like phones, and others act like earpieces. The Garmin acts like an earpiece to offer a hands-free speakerphone while driving. Your Jabra earpiece wants to pair with a phone, not other earpiece-type device.
Apr 18, 2011 | Garmin GPS
Need to put bluetooth in pairing mode and lost instructions
how to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button and your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
May 01, 2010 | Jabra BT350 Bluetooth Headset Headset
Discovery mode
If you mean pairing, then hold the button down until both red & blue lights flash. If your bluetooth transmitter is in paring mode too, it will connect up. Note that the headset must be off before you begin.
Mar 20, 2010 | Jabra BT350 Bluetooth Headset Headset
How do I connect my Jabra Bluetooth to my LG phone? I have lost my manual and cannot get the Bluetooth to connect to my phone,
On back side of earpiece there is a pin hole. Using a paperclip, push on the switch in that pin hole. The display on your earpiece will say ready to pair. The device you are planning to pair with will ask for password. 0000. Accept/done. Go into bluetooth section of device and set up for yes instead of ask so it will auto connect everytime.
Jul 09, 2009 | Jabra BT800 Consumer Headset
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
I dont know how to pair my jabra bt350 with my lg dare from verizon
hello mom. try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Jan 24, 2009 | Jabra BT350 Bluetooth Headset Headset
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Code for earpiece
my brother gave me an ote1 jabra bluetooth w-o user manual and i want to know if it work with my nokia3110c
Nov 17, 2008 | Jabra BT250 Consumer Headset
Jabra BT350 Wireless Headset Logo
323 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
