Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker overflowing and freezing up - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingice maker overflowing and freezing up - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Fix water dispenser
It has to be replaced if its cracked and leaking.If its getting freezed and not working then water running line has to be inspected.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Refrigerator model rb215labp The fridge freezes, fridge drawers freeze, top shelf is too warm
Its not working.Two possibilities,either faulty compressor or issue with defrost assembly.Defrost cycle not working.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE ice maker overflowing
Either your water control valve is leaking while off or ice has formed in the fill tube for the ice maker causing the water to spew in directions other than the ice maker or both. A new water control valve may be needed. Part number WR57X10050 Let me know if this helps. Sea Breeze
Aug 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
238 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
