Question about Maytag M7DH65B2A Dehumidifier
Where can I find a "hose adapter" for my Maytag dehumidifier?
My dehumidifier is set up to drain into the sump well. But that is not working and the tank in the dehumidifier keeps filling up instead. I have checked to see that the little tube in the area where the...
PDF Manual at the link below (you may need to login through facebook to view it).
http://homeappliance.manualsonline.com/mdownloads/e14ad258-ea2f-4910-9194-f07dbe3eca29.PDF
If the hose adapter/hose is connected to the condensate drain correctly but water is still leaking into the tank then their must be a blockage in the pipe.
If you need any further assistance then please just ask.
Aug 10, 2011 | Maytag M3DH30B2A Dehumidifier
I do not have the adaptor for my maytag dehumidifier model #M7DH45B2A to attach the garden hose for continuous drainage. Where can I get one, or could you give me the specifications so I can go to the...
The drain hose connecter, which accepts a garden hose type coupling is an intricate part of the unit. It is not removable. If yours broke OFF, that's a different story. However, that Part # 5214A20027A Drain Hose Connect is no longer available. As are many other parts for Maytag Dehumidifiers, that were manufactured by the now defunct, Fedders.
Unfortunately, I do think you'll be able to run out to the local hardware store and get parts to fabricate one. As the lion's share of the part is internal. http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282294&modelsID=116727&typeName=dehumidifier
I'm sorry I don't better news for you. Thanks for choosing FixYa.
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Codensation Removal
Try making sure the tube that came with the dehumidifier has no blockage. Some Dehumidifiers have the hose screw into the side of the bucket and drain from there. Most newer ones have a plastic tube that comes with them that attaches where the condensate water drains. Good luck - Tech101
Jun 20, 2008 | Maytag Dehumidifiers
Missing hose adapter
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
Aug 15, 2007 | Maytag M7DH45B2A Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
76 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
