Question about Samsung LN-T4061F 40 in. LCD HDTV
Takes a while to start up and turn on. Sometimes purple pixels
When I try to turn on my TV/Cable the receiver comes on, but the TV Clicks for a while. It will eventually turn on. Sometimes when it comes on after a few seconds, the screen has purple pixels. Once TV is warm, everything works fine. Any suggestions or answers?
    Sergeant:
    Champion:
  • 227 Answers
You have a power supply problem, look for bad capacitors normally they are flat on the top, but when they go bad they get like a bubble on top. just replaced them. good luck
Posted on Jul 11, 2010
The tv screen turns from ok to purple and green pixels
do you have speakers set up by your tv if so try moving them away as sometimes the speaker magnets pull on the picture tube in your tv.
Dec 11, 2012 | Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
Mitsubishi TV input's shot/dead?
tried to use other cable wire.if still the same problem it could be a problem in the board. check first a loose or cold solder joints and replaced the crt socket in the picture tube.
Aug 18, 2012 | Mitsubishi Televison & Video
It takes about 5 mintes for my tv to actually turn on. I push the power button and it starts to cycle on and off. Sometimes i get purple spots on the tv when it finally turns on. If I turn it off then on...
hello,
Cycling turn on off mostly from capacitors on PCB power board. Read my tips for cycling power on here. For Purple spot i think because capacitor efect i hope.
Good luck.
Apr 19, 2011 | Samsung LN52A580 52 in. HD-Ready LCD TV
Hi, I have a sony rear projection TV when i try to turn it on it clicks ,buzzes for a for seconds then goes into standby, i took the back off and the buzzing is coming from the ballast board, in particular...
Hi:
That is correct that canister is the lamp, seems its trying to light, If you have not replaced the lamp since you purchased the unit then this is the perfect time to do so. This buzzing from the ballast is normal just means it has received signal to light the lamp. Just start by replacing the LAMP>>>
Nov 10, 2010 | Televison & Video
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Samsung hdtv, purple pixels and trouble turning on
probably the power supply is going out.common problem.
Oct 27, 2009 | Televison & Video
Turn on tv and purple pixels like snow are spread around tv
Write down your serial # (found on the back or on the side) and your model # and call 800-Samsung. The issue has to do with the capacitors and if your TV was manufactured between Dec 2007 and May 2008 they will send a repairman out to repair for free (one time only). I just called and they are sending someone out to repair mine. Apparently there are tons of people experience the same problem.
Sep 12, 2009 | Samsung LNT5265FX 52 in. LCD Television
2004 Chrsyler Pacifica Won't Start
2 possible problem come to mind:
  • Bad ignition switch; faulty switch will occasionally make contact but not every time
  • Bad starter; less likely but possible; a bad starter will function when it's cold but when it heats up, takes much more power to make it work
I hope this helps with your problem and wish you the best of luck. Take care!
Greg
May 12, 2009 | 2004 Chrysler Pacifica
Plasma TV PS-42Q7HX/XSJ
hey, i had this problem with a CRT television once. My subwoofer would cause the same issue in that TV. There is a rather large magnet in the subwoofer that creates a field that will mess your TV up if it's too close to it. not sure if the same applies to the plasma, but i'd definately move it more than 5 feet away from the screen. sometimes it takes 24hrs or so for the tv to repair itself after doing so. hope this helps.
Sep 27, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
234 people viewed this question
Jerry Greenberg
Jerry Greenberg
