Question about Mtd 22" Yard Machine Push Mower
It speeds up and down all the time and runs poorly
Sometimes this problem is governor related..but most times there is a problem with the carburetor. The idle circuit in the carb may be partially clogged or the linkage on the carb is worn and weak. A carburetor/spray choke cleaner could help if you spray it directly into the engine while it is running and even right before starting it up. Best way to clean the ENTIRE carb though is to remove it from the mower...take the lower float bowl off and soak it in some type of solvent/cleaner with the rubber tipped gas inlet needle removed and the float also if it is plastic. For a thorough cleaning, these parts need to be removed anyway....No rubber or plastic carb parts should be soaked with the carbs main body Pahy close attention to the brass bolt that holds the bowl on as it is the main jet and has very small holes in its middle and bottom that must be clear.
Posted on Jul 10, 2010
Aug 11, 2014 | Mtd Yard Machines 38-Inch 12.5 HP...
Apr 11, 2012 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Jul 01, 2011 | Mtd Yard Machines 158cc Briggs and...
Jun 25, 2011 | Mtd LAWN MOWER PART # 983-04053-0637 DECK...
Sep 27, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Sep 19, 2010 | Mtd 22" Yard Machine Push Mower
Oct 15, 2009 | Mtd Garden
Oct 06, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Apr 26, 2009 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
Jul 03, 2014 | Mtd 22" Yard Machine Push Mower
Jun 19, 2014 | Mtd 22" Yard Machine Push Mower
193 people viewed this question
