Question about Sharp 27N-S100 27" TV
The connector for cable of My sharp tv 27n-100s back is broken.what can do to make the cable line workable and connect with the tv
  • 10,594 Answers
RF input jack in tv will be replaced if its an individual part and if RF jack is directly connected on tuner, then tuner will be replaced that needs soldering work on main circuit board of tv.
Local tv repair shop will do the job for you.
Thanks.
Posted on Jul 10, 2010
How do get to service mode for Sharp TV
Hold volume up and channel up when you plug the power cable in. Hope this helps.
Oct 19, 2012 | Sharp 27N-S300 TV
We have a black screen with no picure, but dvd's have picture and so does close caption writing. Any ideas????
Sounds like its either your cable service or the cable being used to connect your cable box to your TV. The cable of course is my first suspect but on your tv how are you connecting to cable it is a coax cable or rca ect. ??
May 28, 2011 | Sharp 27N-S100 27" TV
I have a 27N-S100 TV. It was given to me with no remote. The Cable plug thing in the back is completely broken off, but I was told the TV could work perfectly by using the 3 colored cables (I believe they...
What you're trying to do shouldn't work unless the VCR has a digital tuner in it or your cable company still hasn't converted over to digital as of yet. You will need to get a digital cable box from your cable company.
Connect the av cables to either the front or back of the television. I believe the front is av/video 2 and the back is av/video 1. You have to choose either video 1 or video 2 from the television's menu in order to access these parts of your television.
Connect the cable box to the other end of the av cables and you should be all set. You would change channels with your cable remote and always leave the Sharp television on video or
What you're trying to do: Connect the cable to where it says in on the back of the vcr. and connect the av cables to the vcr where it says out. You will have to do a channel scan on the vcr.
Apr 26, 2011 | Sharp 27N-S100 27" TV
How to hook up headphones to a sharp 27ns100
It looks like your TV has stereo AUDIO OUT jacks on the rear panel (L and R) which you can use to connect headphones. Go to a local Radio Shack or other electronics retailer and ask for help with the required adapter cable and connectors. They should be able to direct you to the product(s) as Radio Shack has these simple adapters and they should cost very little. All you need is a simple RCA cable with the white and red plugs for the TV side and depending on your headphones, either a 3.5mm or larger connector for hookup on the headphone side. They also sell extension cables so you can move away from the TV more. Don't let them sell you anything fancy or expensive as this is really simple.
Mar 14, 2011 | Sharp 27N-S100 27" TV
The antenna/cable connector looks broken. can this be replaced?
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
Cable hookup broken
Sometimes you can replace the rf connector by resoldering it with a replacement rf. You will have to remove the tuner to do this. The big question is did you crack the tuner board or the board the tuner is connected to. You will really have to examine these. In most of my cases a successful replacement rf connector will fix.
Aug 24, 2009 | Sharp 27N-S300 TV
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
Missing Cable Connector
After you remove the tuner from the main board and remove the 2 covers from the tuner, straighten the metal side of the tuner where the hole is for the F connector. If you look at the PC board inside the tuner, there is a small hole in the board directly under the hole in the metal for the F connector. Usually there is a small piece of the old F connector's center pin still soldered in that hole. If it is there, unsolder it and throw it away. The new F connector will be soldered in place over the hole in the side and a small jumper wire soldered from the center pin of the new F connector to the little hole in the PC board directly under it. Be careful when soldering on the tuner's PC board because the parts are extremely small and close together, and lost SM parts and solder bridges are possible. Be sure none of the coils in that area have been squashed over, which is what I usually see when the costomer sticks something in the hole left in the tuner. If the coils are squashed, you can straighten them with a small pair of tweezers or remove them and rewind then around the proper size drill bit. Let me know how you make out.
Aug 09, 2007 | Sharp 27N-S50 27" TV
Sharp 27N-S100 27" TV Logo
56 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
