Question about Invicta Subaqua Noma Iii S
I have a sub aqua 5511 and one of the three markers on the rotating bezel is loose. How do you tighten it?
    Genius:
  • 1,970 Answers
Mcdevito75 here, BEST BET, if you have a warrantee with Invicta, contact them for repair. If not look for a small watch repair shop in your area.
Posted on Jul 10, 2010
How do I use the moveable outer numbered ring on the t49825dh?
The numbered bezel can be used by divers to measure elapsed time on their oxygen supply. Place the zero where the minute hand is now and you'll know when 20 or 30 minutes have passed when the minute hand reaches bezel number 20 or 30.
In the same way, you can use the bezel to tell when 30 minutes have passed on your parking meter if you simply put the 0 on the minute hand when you leave the car. When the minute hand reaches the 30 mark, a half hour will have passed.
Typically, the bezel only turns counterclockwise to keep the wearer from bumping and changing the elapsed time number. On some less expensive watches, the numbered bezel does not turn and is decorative only.
Oct 23, 2014 | Timex Tiex en T49825DH Expedition Military...
Whats the rotating outter ring marked 0 through 60 function on my armitron 20/4664sv
The rotating bezel can be used to measure elapsed time. For example, if the time on your watch reads 10.10, align the zero point of the bezel with the minute hand. Now, say the time is 10.40, the minute hand at 8 o'clock will point towards 30 on the bezel, indicating that 30 minutes of time has elapsed since 10.10.
Jan 05, 2014 | Watches
I have an older skyhawk watch, but the paint came off the bezel so you can't read the numbers. How much would it cost to get them repainted or replace the bezel?
I had the same issue. I found a way that makes the watch look new again. If you buy a sharpie marker and color the whole face It will color in the numbers and around them. t After you have done that, rub a moistened rag over the face of the watch. This will remove all the excess black marker, and it should look new for a few months.
Dec 19, 2010 | Citizen Blue Angels Skyhawk Watch
Invicta 3215(or similar watches). What is the name of the 'clicking' mechanism on the rotating bezel? there is a hole for it the case when bezel is lifted.
mcdevito75 here, I"m pretty sure the mechanism is called a Ratchet mechanism, most likely for all watches with rotateing Bezels.
Aug 03, 2010 | Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
One of the hourer marker as come loose from the face and is wedged between the watch face and the crystal.
In order to fix this problem you will have remove the case back and movement and re-locate the marker back to the correct location. It probably came loose because it was not tight enough on the the shaft. So some tightening will be required. All of this is maybe something that you do not have the expertise to do and therefore you may need a watch repair person to do this. Best of luck.
Oct 23, 2009 | Kenneth Cole Watches
Navitimer 2 rotating bezel has gone very stiff to turn how can i free it up?
This depends on what exactly is causing the problem. If the bezel is bent from a sharp blow it would have to be replaced. It could be there is dirt under the bezel. To clean this there are two possibilities. If your bezel has screws around the outer edge they will need to be loosened or unscrewed to remove the bezel. These are small screws so be careful you don't loose them. The bezel should then lift off. Clean it with mild soap and water and dry it well. Be careful of the bezel spring. it is easy to break the little fingers. Wipe off any dirt on the case and set the bezel spring and bezel back on the case. Use Red locktite on the screws and reinstall them. If you have markers on the bezel that come off when you remove the screws be sure you keep track of them and the screws that went with them.
If your bezel does not have screws but fake ones then the bezel should be removed by a qualified watchmaker because the bezel could be bent or damaged when removed.
Hope this helps.
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Watches
What is the purpose of the rotating bezel on the Callaway CY2058? It has no markings, which it needs to be useful.
If you have no markings on bezel there is no practical use for this feature.
Bezels with markings are used as a tachymeter (for calculating speed of the moving object) or as a countdown timer for sporting events or diving.
In your case bezel is becoming loose and thats why it is turning as I can't see the point why the watch should be fitted with rotating bezel with no markings on it.
Rate me, please.
Jul 31, 2009 | Callaway CY2058 Sport Series Watch
Real or Fake
check a bunch of things...even great fakes slip up on one or two details
check the luminous markers, are they painted well?
check the bezel luminous marker, does it match an authentic?
check the wing logo on the dial
look at the font for the date
look at the band pins (they should be screws-round or flat depending on model)
check the crystal, should have no reflection and a purple hue when viewed at an angle
under the lugs will be a date etched in to the case
the bezel will have a small "B" etched in between 11 and 12 on the side, not the face
Bottom line, unless you have paperwork in hand and a verification that the seller bought it from Breitling, you are probably looking at a fake
Oct 08, 2008 | Breitling Hercules 246/GRY/PROF
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
Invicta Subaqua Noma Iii S Logo
225 people viewed this question
Top Invicta Watches Experts
Arturs Kalnins
Arturs Kalnins
Andrew Taylor
Andrew Taylor
Are you an Invicta Watch Expert? Answer questions, earn points and help others
