Question about Acer 3003WLMi Notebook
How to disable Laptop battery?
My Laptop battery is basically dead, because of this it makes it so that my keyboard and touchpad don't work on start up. I think that this is a common problem with acers.
I can make my laptop work by simply removing the battery. The problem is that I don't want to leave the battery out on a permanent basis to avoid damage to the laptop and I don't want to get a new battery because.... I'm cheap! and I usually keep my laptop on A/C power anyway.
Is it possible to keep the battery in but make it so that it doesn't try and charge?.... if its not a stupid question.
  • Lee Henderson Apr 20, 2008
    "http://www.fixya.com/support/t144391-keyboard_touchpad_problem"
    Here is a link to another person who has the same problem. It is the main battery that is the problem, its been a bit iffy for a while because to wouldn't hold much of a charge before this problem occurred.
    I think that it is somehow stealing the power from the keyboard at start-up in order to charge, at the moment I remove the battery when I want to boot my laptop and then put the battery back in after a little wile. I am amusing that the problem occurs at start up because that is when large amount of power is being used.
    Basically I am getting fed up of pulling my battery out and prating around with it and I am worried that after a long period of doing this would damage my laptop (even further lol). What I want to know is if there is some setting that I can change to stop the laptop for using the main battery.
    Scholar:
  • 144 Answers
I really never seen such a problem.Your keyboard and mouse doesn't work !!! it only work when you remove the battery of the notebook ??? Do you mean bios battery or a noraml laptop battery ?? Give us more detail.
takecare.
Theknack
Posted on Apr 19, 2008
  • Technocom
    Technocom Apr 20, 2008
    I'm sorry for late reply. I recently seen one such a problem with one my customer computer.The problem is that the battery is never fully charged and sometime the computer won't startup.I detect that the adapter was the problem due to not continues
    power supply.If I use meter to check I get 19V normally but if I use scope to see,I found that the electricity is not continue.So went I change the adapter,everything work fine and also the battery was fully charged to 100%!!!. So I recommend you to find the same adapter and test with it.
    Takecare.
Laptop touchpad not working
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 09, 2012 | Toshiba Computers & Internet
Fn-F9 not working
From the description the laptop keyboard needs changing, check www.ebay.com Type make and model of laptop, refine search to keyboard, but I would use external keyboard first to verify. To disable the touchpad go into device manager, check list and click on the left box, right click and highlight disable, press ok or apply.
Jun 23, 2012 | Toshiba L355-S7905 (PSLD8U0Q3033) PC...
My toshiba sattilite laptop, soft touch cursor is not moving and opening the icons
Hi jilglh...
Try this method
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | Toshiba Computers & Internet
I need tp know how to unlock my touchpad for my Presario CQ62 laptop
Hi lilzett14...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using a Function key on the keyboard and the Fn key.
Sep 16, 2011 | Computers & Internet
My Acer Aspire 5732z inbuilt mouse works and stop, why?What is the solution to this problem?
Hi faithfulnice...
Sep 11, 2011 | Computers & Internet
Touchapad not working of my laptop hpprobook 4510s Help me for the same ASAP
Hi palkarprasha...
Sep 10, 2011 | HP ProBook 4510s FM849UT Notebook
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Sep 04, 2011 | Computers & Internet
Inspiron Keyboard Jumps Around
Install the latest touchpad driver from support.dell.com
There is a setting in the touchpad tab of the mouse driver. Either Enable PalmCheck or Disable touchpad when typing (Depends on Synaptics or Alps drive I believe)
With palmcheck enabled, the touchpad is disabled when typing
Jan 24, 2010 | Dell Inspiron 1420 Notebook
Thanks for helping, murpium and poplock, but...
Dear fix-the-prob Unfortunately there is no magic key to enable you to do this. Computers do not have 20 backup systems like airplanes. Which would be nice but it would cost like one too! You have two options though to solve this,
  1. Firstly either change the laptop’s keyboard (which is a bad solution if the keyboard is fine and the problem is actually the motherboard)
  2. Second is to find any USB keyboard (easy these days) plug it in an USB port at the side of the laptop. The bios is forced to see this keyboard instead of the laptop’s.
Regards Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 12, 2008 | Acer Aspire 5100 Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Acer 3003WLMi Notebook Logo
2,199 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
