Question about Polaris 380 In Ground Pool Cleaner
Hello I have a polaris 380 and a lot of air is coming out of the pressure releif valve which is effecting operations of the polaris. I have replaced this unit and still have the same problem, I need help.
  • John Rodgers Jul 11, 2010
    I need help with this problem, took the polaris to leslie and they could not find the problem.
  • 532 Answers
It may be you did not get the good pressure relief valve when you replace the other time. You will need to replace the pressure valve again if not it will affect the operation of the polaris.
To get the original pressure relief valve, order for tour pressure relief valve at this website. www.thefind.com/garden/info-replace-pressure-relief-valve -
Thanks for contacting Fixya.
Posted on Jul 11, 2010
  • 2,272 Answers
It sounds like the water could be getting over heated. Has the temperature of the hot water out of a tap gone way up? (a meat thermometer should be in the right range to measure this by flowing just hot water into a container and measuring the temperature of the water in it.) Be very careful, it sounds like it could well be very very hot. Check the heating element and the thermostat. In case if you notice any water coming out of pressure relief valve then its faulty or loose valve. 2 possibilities To much pressure and its causing the relief valve to open in compensation The valve is defective and needs to be replaced. If the valve checked out faulty or cracked.IT has to be replaced.Cost of new valve is near to $7.Click this link to buy the valve. http://www.bestbuypoolsupply.com/polaris-380-parts.html
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
  • John Rodgers Jul 10, 2010
    Hello the water is warm not hot and the valve has been replaced already with the same results.. One other issue when I performed the rpm on the wheels they were within specs however once I submerged the unit back under water they stopped turning and the tail also stops.
My Polaris 380 disconnects from quick disconnect. seems like a lot of pressure behind it.??
Take out the wall fitting of each of the two locking taps are probably gone there are restricted behind the wall fitting blue or red either remove or I stall
Aug 31, 2016 | Polaris 380 Pool Cleaner - Pressure
Why on a polaris 380 would water pour out of pressure relief valve and not make it to vacuum
check inline filter or check to see if hose is collapled sometimes the bend where they go into the polaris
Jul 12, 2014 | Polaris 380 In Ground Pool Cleaner
I have a polaris 380 which has stopped working and the pressure relief valve is opening. The inline filter appears to be clean, but I am thinking that there must be an obstruction in the polaris nozz
pressure relief valve on sidewall check oring make sure fitting has both tangs if missing replace if ok see if inside Polaris there is a obstruction
Jul 15, 2012 | Polaris 380 In Ground Pool Cleaner
Have had my current Polaris 380 for around 6 years. Nothing has changed...but suddenly the cast to my backup valve split 3/4ths of the way around above the threads. Replaced with backup valve from...
It is likely a coincidence but you may have a restriction of the water downstream from the device. This would cause a higher pressure and might therefore add to the stress on the backup device. Regardless of the cause you still need to new backup valve or a new part to replace the part that split. They are not hard to replace if you can get it apart.
If you have trouble getting it apart you can bring it down to Leslies Pool Supplies and they can put it back in order for just the price of parts.
I hope this helps.
Sep 04, 2011 | Polaris 380 In Ground Pool Cleaner
I think it is a coincidence. On the other hand, there could be a restriction downstream causing the pressure to be too high. I would check for this but either way you will need to buy a new one. I hope this helps.
Having problem with polaris 380 not moving. just replaced back-up valve and having a different problem. there are three small devise on hose that are spraying water.
If the wheels are spinning independently you have broken drive belts. The hose swivels are leaking also which could lower the pressure to the head.
Jul 08, 2009 | Polaris 380 In Ground Pool Cleaner
380 unit floats to the top, doesn't move around pool
Check the following three things. One of these should correct the problem you are having with your automatic pool cleaner.
1. Confirm that the blue
restrictor disk is installed in
the UWF to decrease water
flow. Or, install the red
restrictor disk to decrease
water flow even more.
2. Check the wheel RPM. If
more than 32 RPM, unscrew
the pressure relief valve to
decrease water flow
to cleaner. Note: The
pressure relief valve should
only be adjusted when a
restrictor is installed.
3. Verify the back-up valve is
cycling. Hold the valve out of
the water and watch the jet.
It should come on and go off.
Jun 05, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
101 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
