Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
How do you replace the door handle? I need to know how to get to the screws. Does the door come apart or do I have to get the handle to come apart?
    Genius:
  • 1,970 Answers
Mcdevito75 here, This may involve a special procudure, not to mention tools and maybe a special adjustment to keep Microwaves from leaking into your home. BEST BET, look for an appliance repair shop in your area.
Posted on Jul 10, 2010
How to disassemble the door of gmh5205xvs-0
On the inside of the door there is a plastic frame that goes around the edge with 2 slots in it that the door latches go through. You have to very carefully pry the frame outward to remove it. First check with a parts supplier to see if your handle is available because some microwave doors are not repairable----you need to purchase a complete door. If the handle is available then attempt to remove the frame as I described before. Once the frame is off you should be able to see the handle screws. If they are still hidden the outer door frame and inner metal door will need to be separated also. They too just pry apart with plastic tabs holding everything together. Replace handle and reassemble. Not hard just time consuming and must be done carefully so as not to break the plastic parts.
Feb 26, 2015 | Whirlpool Microwave Ovens
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
How to install WB15X10022 GE Microwave Handle.
This is a generic answer
Open the door and look carefully for a plactic strip that may be covering screws. If none. look on the bottom edge or the edge with the hinge. Remember, someone had to assemble the door so there has to be some way to disassemble it. I have never seen one that can not be opened (glued, cemented or welded closed) Remember, most doors are spring loaded and may snap shut on you with the door partially removed. Also, keep in mind the process you went through to get it apart. You will have to reverse that process. You may want to take pics with your cell phone as you progress.
Once open (and you may need a 'Torx' tool to remove the screws), replacing the handle should be simple.
Let me know how you make out.
a
Sep 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
Need to replace the handle I have the part but how do i desassemble the door properly
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jun 03, 2009 | Microwave Ovens
GE Handle replacement
The handle is part number WB15X335 and you can find it online from several sources. You can replace the handle alone. You do have to remove the door inner panel to get to the handle screws.
Jan 27, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 06, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
131 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
