Question about iLO 2600 Television
My ilo tv will not change from channel 3. The
My ilo tv will not change from channel 3. The only button that works is the power button. What is causing this? The remote also does not control it.
    Problem Solver:
  • 5 Answers
You may have accidentally pressed 'Favorite' on the remote which will lock the controls. Try pressing 'Favorite' to unlock the controls.
Posted on Aug 22, 2010
How do I change input on tv. the channel up and down buttons do not work anymore, and we do not have an ILO remote (only Directv remotes), and it's only allowing me to change channels, not inp
About the only thing I can think of is getting a new remote that can accept the programming of the ILO TV and control it that way. A remote I use for work is a URC. They work great.
Jan 04, 2015 | iLO IWT3206 TV
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
The iLO TV will not change channel by remote or by buttons on front of TV.
how do i change the channel on the front of my tv it is a ilo
Jan 10, 2011 | iLO IWT3206 TV
Cant change channel
The up/down ch buttons will only go to channels that are set up in the tv....go to the menu....settings....and set up the channels you wish to view, once the channels are set up, the buttons will work
clarkco
Feb 27, 2009 | iLO 3200 32 in. LCD Television
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
125 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
