Question about Proform 730 Folding Treadmill Model PFTL71104 - !
I have a Pro-Form 730 Sightline treadmill and broke the right link arm when moving it. This part is no longer available and none of the suppliers such as Treadmill Dr, Fitness Repair, Sears or even Pro-Form have the part. Any suggestion for a replacement, such as a similar part that could be modified to fit, or how the machine can be repaired.
5 Suggested Answers
SOURCE: I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Posted on Aug 21, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
SOURCE: Prosoft Plus Pro-Form 500i treadmill
i push the buttons 6,7,8,9, and the incline up works but all the other buttons dont not even the start button,plz help,,,,,aaaaa, :(
Posted on Aug 07, 2011
I need a wiring diagram for a pro form 730 treadmill
There are many different kinds of Proform 730 models. Please search for or find your specific Proform model here and look at the parts list for the accurate wiring diagram for your model.
Oct 20, 2011 | Proform 730 Folding Treadmill Model...
A friend of mine gave me her old Sears Pro Form Space Save 730 SI Treadmill..I was able to use it twice and for some reason I cannot start it...It lights up but does not move...I do not have a Manual..Is...
hi,
I have the manual of Pro Form 730si . If you can give your email as a replay for this then i will sent the manual to your email id. I can't upload the manual through fixya. Because its a pdf file.
OK
Sep 18, 2011 | Proform Exercise & Fitness
My pro form treadmill - panel lights come on but belt not operating? Any ideas how to repair or who would call out - Derbyshire area? Thanks
If the light are on and when pushing the console start button the oval track lights (on the console) should move. If not, then your console is bad. On most Pro Form consoles you have to replace the entire console. Individual parts are not available.
Jul 28, 2010 | Proform Exercise & Fitness
My pro form 730 runs then its stops after about 30 mins
If you have not lubricated the deck I suggest you doing so you may purchase the lube @ Gymparts.com Part # TM001
May 13, 2010 | Proform 730 Folding Treadmill Model...
My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
119 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
