Question about Microsoft HP Pavilion DV6276US Notebook PC
How do i turn up the backlight. i cant really see the display
    President:
  • 2,571 Answers
The settings for this is in control panel and power options
Posted on Jul 10, 2010
Display is stuck in negative effect how do i fix it
Do a hard reset by pulling the battery (if you have access) if not hold down the power button until it turns off. The negative effect you're seeing is really a backlight that is turned off, probably due to low battery, or it has died completely. If turning it off and turning it back on doesn't fix the issue you may have a dead backlight.
Jun 07, 2015 | Tablets & eReaders
Where can i find the power inverter in hpg62 screen
It miight be the backlight for this unit. It all depends on whether the screen came with the backlight. There is a remote chance that the display circuitry on the motherboard is faulty too. Try to plug a monitor into the VGA port and check to see if it is dim there too.
Sep 11, 2012 | HP Computers & Internet
2006 model A1181 2.0 Ghz 13.3 inch black macbook. Screen was losing backlight if opened too far. Shop said they could fix, and then said sorry totally broken, no display now. New shop replaced inverter, no...
If the new shop was repairing it with respect to the problem of you having no backlight, take it back to them and show them that it is not working and demand that they repair it correctly. Failing that you should really take it to a mac authorised repair shop i.e. an apple store to get it repaired.
Aug 28, 2010 | Apple MacBook (MB402LLB) 133 in Mac...
Tracker 5600 cant see display worked fine last week
Last fishing trip was at night and due to the brilliance of the display my son turnred it down and unknown to me actually turned it off ( the backlight) and it was only after trying everything else found it was the simple solution of turning it (the backlight) back on. oops
Jan 05, 2010 | Navman Tracker 5600 GPS Receiver
Acer aspirw 5100 brightness
1.The Function key (Fn), and the F6 key are pressed to turn the Backlight off to conserve power.
2.The Fn key and the right side arrow key, are pressed to increase Brightness.
You have a TFT LCD monitor screen. (Thin Film Transistor)
The LCD screen cannot be seen clearly without a Backlight.
The Backlight is a CCFL. Cold Cathode Fluorescent
tube. Resembles a small fluorescent tube used in residential, and commercial lighting.
The Backlight can go bad after time, and weaken.
If so, it will have to be replaced.
Sounds easy, it isn't.
The TFT LCD monitor screen is made up of layers. It's enclosed in a thin metal frame. Resembles a picture frame.
The frame is removed, after removing the LCD screen from the laptop's top cover.
The LCD screen transparent outside layers, are separated partially from the rest of the LCD screen.
The Backlight is removed out of the side.
This gives you an example of removing, and replacing an average Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Recommended job for a pro.
Dec 28, 2009 | Acer Aspire 5100 Notebook
Display dark
The backlight is turned off. Slide down the power switch (on side of unit, lower right) and hold it for more than 2 seconds. This should turn the backlight on.
Apr 03, 2009 | Sony CLIE PEG-TJ35 Handheld
LAPTOP MONITOR LIGHTS IS OFF
If it's under warranty you need to send it in. This is either a bad inverter or a bad backlight. If you can see windows and such, you can attempt to turn up the brightness, but it shouldn't be 'that' dark. I am absolutely positive it's your backlight. The only thing you may be able to do is to open up the laptop and unplug and replugin the inverter. I suggest you let a techie do that. However, if you really want to fix it yourself, just type your laptops model into ebay and search up inverter or backlight, and see what comes up. They shouldn't be more expensive than 40 bucks realistically. LCD's on the other hand are hella expensive. (Which, if you can see the display, like icons and such if you look closely, it is not the LCD which is the problem, just the backlight which typically rests on the bottom of the LCD bezel behind everything) The backlight is obviously important to see stuff that the LCD is producing. Also, one quick note, sometimes you can manually turn off and on your lcd inverter by pressing F1 or F2 while in the desktop while holding down the Fn key.
Hopefully this helps, remember to rate!
Stay spicy and happy lappying :)
Dec 16, 2008 | HP Pavilion dv6000z Notebook
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Backlight
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
May 05, 2008 | Apple iPod nano
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
