Question about Kenwood KDC-MP235 CD Player
What color wier do i hook up my amp to the head unit?
  • 407 Answers
The only wire that you should hook up from the amp to your head unit is the remote power wire which is the blue wire on the wiring harness for the head unit. Sometimes they are blue with a white stripe. Hope this helps.
Posted on Jul 11, 2010
I just bought a Jensen vm9215bt head unit. And I do not know how to hook up my subwoofer. I have three cables coming from my amp. I have one of them so the amp will turn on, I have that one connected. But...
Most amplifiers have a common color code to hook them up. On your head unit, there should be a blue wire. That is your amp. Turn on lead. The positive + symbol goes to your battery +. And that lead is usually red. Your negative terminal - is this symbol and the wire s usually black. That either goes to the - side of the battery or grounds to car chassis. The sound inputs to your amp. either by RCA cables or high speaker level input. That depends on your amps. set up. If you have any questions, post back and I'll try to reply by next day or two.
Oct 02, 2013 | Car Audio & Video
Radio works but no sound
Its the wiering to the speakers. Or if u have it hooked up to an amp it might nkt be hooked up right.
May 03, 2013 | Toyota Tundra Cars & Trucks
I just installed a new deck but no sounds or feedback from speakers what am I missing
You need to answer a few questions first. Do you have a factory or aftermarket amp? Did you use tape or crimps to attach the harnesses together? Did you use the proper harness? Is the head unit new or used? Check the fuse(s) in the back of the head unit. Then check your wire connections. Check that they are hooked up to the right colors and they are solid.
May 02, 2011 | Kenwood Car Audio & Video
I have my amp and and subs hooked up right but i have multiple component wires on the back of my vm 9412. i need to know what to hook my component wires to in the back of my head unit and also need to know...
If you are running your speakers/subs from an external amp, then you wouldn't use any of the wires in the back. Usually you don't have any type of menu to change to make anything work. Some units have the ability to turn the signal off to the amp. What color are the wires in the back that you have remaining?
Apr 13, 2011 | Car Audio & Video
My 1995 chevysuberban has no speakers and would like to know how to wier the speakers in my car?
The car is not important .Connecting speakers to any unit is basically the same. there should be a color coded wire harness connected to your head unit. The speakers are as such: White & White with black stripe (Front Left) Grey & Grey with black stripe (Front Right) Green & Green with black stripe (Rear Left) Purple & Purple with black stripe (Rear Right) The Solid colors are (+) Positive and the Stripes are (-) Negative. Connecting any one of these incorrectly will result in phasing problems. Hope this helps. dreamsystems
Feb 09, 2011 | Car Audio & Video
I have my wire that is suppose to hook up to my head unit and to my remote on my amp but the amp stays on when i turn off amp how do i hook up wires right?
Should have a remote wire off of your radio....
Usually blue in color. Make sure it it says remote. If that don't turn your amp off, try to power antenna wire. One should work
Jan 02, 2011 | Lightning Audio LA1.300.2 Car Audio...
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Eclipse DA7122 amp
Did you hook up your other amp again to make sure nothing happened in your wiring? *curious*
Apr 09, 2008 | Car Audio & Video
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
Kenwood KDC-MP235 CD Player Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
