Question about Dell Dimension 2400 PC Desktop
Power fuse computer won't power up, is it the fuse?
  • 23 Answers
Most of time it happens when your power is not connected properly or you should try to fighure out ram is connected properly or try by another main power adaptor which might failed, ok?
Posted on Jul 10, 2010
Why won 't computer communicate with code checker
Check the cigarette lighter fuse. This is what powers the DLC. If the fuse is good, check and see if the lighter works. If not, you have a bad wire. Code readers have to have power from the car. Most scanners have there own power and will read the computer, unless the data wire is bad or the computer is bad.
Mar 28, 2015 | 1995 Buick LeSabre
There was a power outrage and now my computer won't turn on?
Check the source of power to your computer. Your computer should be plugged into a protection strip. Make sure that the protection strip reset button is reset. If that is ok, check the circuit breakers in the fuse box.
Jan 29, 2013 | Computers & Internet
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Harmon Kardon CDR 2. Won't power on. Fuses test good. any suggestions?
The problem is more than likely in the audio output ic usually heatsinked, part of the power is fed back into the system energizing the circuits.
Apr 17, 2012 | Audio Players & Recorders
I can't get hooked to computer on truck withobd2 code reader. they won't link up. what is possible problem? I checked the fuses, all are good.
Check the fuse for the Cigg. lighter or Acc. fuse. If the fuse is blown you wont be able to communicate with the DLC because this fuse supplies power to that circuit.
Oct 06, 2011 | Cars & Trucks
Dell Dimension 2400 PC Desktop Logo
65 people viewed this question
Alun Cox
